07-31-2013, 10:08 AM | #1 |
67 swb stepside wheel fitment
so i know this is been covered and beem lookign but cant find the answer that i need, i see alot on tubbing but since i am running open bed (floorless) all i need to do i trim the bed side up a little, but i am about to order a set on the mob steel wheels and wanted to run a 18x10 up front and a 20/12 in the rear can i do that or should i stick wit a 18x8 and 20x10, will i have any fitment problems and what backspace should i use to have the rear wheels tuck, also with the 18x10 i should still be able to turn stop to stop, the truck is going to be a custom frame that will sit about half inch from rocker when layed out, and about a 4 inch when aired up, if that helps, with full custom cantilevers.
07-31-2013, 11:02 AM | #2 |
Re: 67 swb stepside wheel fitment
anyone.. maybe a link to get me where i need to be.?
07-31-2013, 12:10 PM | #3 |
too many variables. i dont think a 10" wide up front would work. the 12" would work on the rear depending on backspacing and of course cutting the bedsides.
07-31-2013, 02:31 PM | #4 |
i think im going with 18x8 and 20x9
thats what mob steel carries |
07-31-2013, 10:11 PM | #5 |
Yeah, 18x10 laid out is asking a lot up front.
18x8 +4.25 BS should do it for you up front. 245/40/18 20x9 +5.25 BS will make it work out back with the right size tire. 265/35/20 Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
08-01-2013, 04:08 PM | #6 |
502ms thanks for the input you think 245 is the widdest on the back your build and another build on here influenced me building a stepper, i wanted to try a 275 or up will it fit in the fender well in the rear, what sixe are you runnign and what is the clearence you have.
08-01-2013, 06:09 PM | #7 |
67-72 parts collector,…
My opinion.
Build the chassis first. Buy wheels last. That way you can measure for correct fitment. Posted via Mobile Device
