Old 07-31-2013, 11:27 PM   #1
longbed65droppedc20
65 C20 transmission.
[I]my 65 c20 had a 3 in the tree. now it's a four speed manual trans on the floor. I would. like to make it an automatic on the column. could you please let me know what trans. I would need. current eng. is a 327 /I]
longbed65droppedc20 is offline   Reply With Quote
Old 08-01-2013, 01:05 AM   #2
jtrichard
Re: 65 C20 transmission.
if you are NOT looking for OD then THM350 or THM400 would your best bet
jtrichard is offline   Reply With Quote
Old 08-01-2013, 01:05 AM   #3
Captainfab
60-66 Nut
The C20's were available with the TH400 originally. If you plan on using it hard, I would go with the TH400. If it is mostly a cruiser/driver, then a TH350 will work just fine. However since most C20's had fairly low gears, an upgrade to a 700R4 will keep the engine rpm's down and up your mpg's a bit.
Old 08-01-2013, 10:45 AM   #4
Budman56
Budman56's Avatar
captainfab I have heard lots of people say to go to a 700r4, why is that? arent they electronic and dont you have to have a computer or switch to run them? I have one in my truck but havent been able to drive it yet, the transmission shop said they made it so that I didnt have to have a computer, will it still work? what did they do to make it run without the computer?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 08-02-2013, 01:31 AM   #5
Captainfab
60-66 Nut
NO,the 700R4 is not electronically controlled. The successor to the 700R4, the 4L60E, and the 4L80E are electronically controlled. The 4L60E and the 4L80E can be built as a full manual trans. When installing the 700R4, two things are very, very important. 1) the TV cable needs to be connected and abjusted correctly, as well as the carb connection having the correct geometry. 2) the torque converted lockup needs to be connected and operating. There are many, many, many threads in the 'Engine and Drivetrain' section about the 700R4 as well as the other 2 transmissions.
Old 08-01-2013, 11:48 AM   #6
padresag
1 question to ask and that is what are you going to use it for. if you are going to use it as a truck to carry loads and or pull a trailer than the 400 is more the trans to use depending upon your budget. if you just want it for going to church and driving around (highway driving) than a 700r4 would be the choice'
you could use an a/t column from the same vintage that you have or you can install a later model tilt column(not difficult to install)
ron
padresag is offline   Reply With Quote
Old 08-02-2013, 12:59 AM   #7
longbed65droppedc20
I will be using it around town. not much work load. but would like to be able to help friends pool a car if needed.
Old 08-02-2013, 01:03 AM   #8
longbed65droppedc20
I have an automatic shift column. with tilt how can I measure to know. if it will fit
Old 08-02-2013, 02:11 AM   #10
longbed65droppedc20
Don't know what it's out of
Old 08-02-2013, 02:14 AM   #11
longbed65droppedc20
thanks padresag but I have a 65
