08-02-2013, 10:03 PM | #1 |
Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm assuming that the coilover shocks that come in the Porterbuilt stage 2 setup for the rear end are just the sleeve type and I would like to cross reference the part number to a true coilover shock. Thanks for any help.
Scott |
08-03-2013, 09:01 AM | #2 |
67-72 parts collector,…
Re: Anyone know the coilover part number that comes with the Porterbuilt stage 2 kit
I'm confused by your question.
As far as I know the Stage two rear kit comes with standard KYB shocks. The Porterbuilt rear coilover kits do use REAL coilovers. They are RideTech's newest coilovers. ($$$) http://www.ridetech.com/store/coil-overs/
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-03-2013 at 09:16 AM. |
08-03-2013, 09:17 AM | #3 |
Keith,Ok you've always have been there to help me out and your the reason I know anything about any suspension at all. I'm baffled what's confusing that I said.
Scott |
08-03-2013, 09:24 AM | #4 | |
I think Fox makes these for RideTech and I've heard good things about them. They are available in 3 different versions: "Available as a fixed valve, rebound single adjustable, or triple adjustable shock."
08-03-2013, 09:19 AM | #5 |
I may understand your wording now.
Porterbuilt sells a coilover kit that uses a 4-link rear suspension. He also has a coilover kit that uses his tubular trailing arms. (I assume this is the Stage 2 Coilover kit) Both still use RideTech's coilovers,... which like you said is a "monotube" design.http://www.ridetech.com/tech/coiltech/#cutaway
08-03-2013, 09:25 AM | #6 |
Ok thanks for the info, I was also wondering what the part number was to cross reference. Thank you Keith
Scott |
08-03-2013, 09:28 AM | #7 |
I would just contact Porterbuilt directly.
08-03-2013, 09:30 AM | #8 |
I think I'd like to go with the triple adjustable coilover. I didn't realize there were different options available.
Scott |
08-03-2013, 09:39 AM | #9 |
I will call them Monday. Thanks Keith, you always come thru for us here on the board.
Scott |
08-03-2013, 11:23 AM | #10 | |
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
