Old 08-04-2013, 08:03 PM   #1
vannatta20
vannatta20's Avatar
LS3 heads versus LS6 heads?
I have a 6.0 lq4 engine and came across a set of Ls3 heads with the truck intake for a great price. I also just bought a set of LS6 799 heads for it. I dont know which set to install now.....The ls6 heads are low mileage but the LS3 heads have about 190000 miles on them. I can get a new LS3 intake for 200$ or use the truck intake. Its a daily driver and wanted the LS6 heads for increased compression and torque. The LS3 make a lot more horsepower though...I can sell the LS3 heads easily and buy a nice intake for the LS6 heads to dress up the engine and get a bit more power. What should I do??
vannatta20 is offline   Reply With Quote
Old 08-04-2013, 08:43 PM   #2
69CST6.0
Re: LS3 heads versus LS6 heads?
Depends on your budget which way you go. The ls3 heads will give you more power but you will need a rectangular port intake and a aftermarket throttle body if going dbc. Also the cam splits are a lot more exhaust biased for the ls3 heads. BTW 799 heads are 5.3l truck heads, They are the same as the 243 ls6 heads minus the sodium filled valves.
69CST6.0 is offline   Reply With Quote
Old 08-10-2013, 12:30 PM   #3
Super73
Super73's Avatar
Be careful what you say as "truck heads" can be very confusing. Early 5.3's did not wear either version of the LS6 castings.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-05-2013, 10:35 AM   #4
Jon01
Jon01's Avatar
On a stock displacement lq4 I'd just put the cathedral ports on it.
Jon01 is offline   Reply With Quote
Old 08-05-2013, 11:47 PM   #5
Blackpony
Blackpony's Avatar
The 799 heads have a larger combustion chamber that will keep your cr low. I would do the ls3 if your budget will allow to property set it up.
Blackpony is offline   Reply With Quote
Old 08-06-2013, 05:55 AM   #6
vannatta20
vannatta20's Avatar
799 have the smallest chamber out of the 3 pairs of heads I have now. 317s and 823 heads are about the same at 70cc. 799 are 64cc so they will bump up compression
Old 08-06-2013, 10:05 PM   #7
Blackpony
Blackpony's Avatar
My bad you are correct. I was thinking about the 317 truck heads. All these different casting numbers get me confused sometimes.. haha I am use to building sbf's..
Old 08-07-2013, 07:41 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
The genIV 6.0L LY6 motors come with L92/LS3 style heads from the factory and make great power with just a cam swap.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-10-2013, 04:58 AM   #9
vannatta20
vannatta20's Avatar
Well i ended up selling the LS3 heads so ill see how the LS6 heads do with a moderate cam in my 6.0. I have a 6.0 with LS3 heads on my 68 firebird and ill see how this combo compares.
Old 09-02-2013, 06:17 AM   #10
smoky02
Location: Sunny, Florida, some might call it South Alabama
vannatta I did the LS3 heads and intake on my LQ4 and love it.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 09-04-2013, 05:35 PM   #11
Kainedogg
Kainedogg's Avatar
I was thinking of doing the LS3 heads my self but for the added cost and the hp increase in the higher rpm range, it just didn't make sense for my truck. If under the other hand if I was building a 408" stroker then the best bang for the buck heads would be the LS3's all day, especially with the valves now unshrouded. On a different note I have driven a buddy's truck with the LY6, cam and tune and it felt as quick, but not staggeringly quicker than a mutual friends older LQ4 with shaved iron heads and very small cam.
Kainedogg is offline   Reply With Quote
