Old 08-05-2013, 12:03 AM   #1
mm1077
Active Member
mm1077's Avatar
My 78' 2wdk5 progress
Purchased my 1978 2wd k5 in August 2012 from the original owner with all of the original records since new. It's ran pretty good since then, but when pulling our camp trailer this June it almost left me stranded so I decided to make some upgrades! Future plans are to lower (I have 3" spindles and 4" drop leafs already) and do a full top conversion (have the window frame already). I'll try and keep this thread updated with pics as I make progress!
mm1077 is offline   Reply With Quote
Old 08-05-2013, 12:09 AM   #2
mm1077
Active Member
mm1077's Avatar
Re: My 78' 2wdk5 progress
Old 08-05-2013, 12:12 AM   #3
mm1077
Active Member
mm1077's Avatar
Old 08-05-2013, 12:22 AM   #4
mm1077
Active Member
mm1077's Avatar
Here's what I've finished up over about the last 6 weeks
Edelbrock 1406 carb
Edelbrock performer manifold
Edelbrock e-street aluminum heads
Comp cams 262/270 cam / lifter kit
Comp cams pushrods
Comp cams 1.5 roller rockers
Edelbrock performer fuel pump / line kit
Hedman long tube headers
Summit racing street and strip mufflers (but I'm replacing w magnaflow 18" case mufflers this week and getting the exhaust routed over the rear axle)
New alternator
Aluminum finned valve covers/air cleaner
Vintage sun tach
Old 08-05-2013, 12:47 AM   #5
mm1077
Active Member
mm1077's Avatar
Put in some low back buckets I found on Craigslist a couple months ago
Old 08-05-2013, 12:29 AM   #6
mm1077
Active Member
mm1077's Avatar
Got my tach installed today...
Old 08-05-2013, 11:59 AM   #7
Jabes1
Jabes1's Avatar
Looks good, nice work! The vintage trailer looks cool behind the K5... We plan on pulling ours with my truck too.
Jabes1 is offline   Reply With Quote
Old 08-07-2013, 01:24 AM   #8
mm1077
Active Member
mm1077's Avatar
Had the day off today(well most of it anyways) and took the blazer down to get the exhaust finished up.
Before:
(And finding that x-member off a 74 gmc I think was the highlight of this whole thing so far lol)
Old 08-07-2013, 01:30 AM   #9
mm1077
Active Member
mm1077's Avatar
After:
Sounds great and runs better too.
Old 08-07-2013, 02:02 AM   #10
Jabes1
Jabes1's Avatar
Very clean! One day one of these or a Crew Cab will be the family vacay hauler.
Old 08-07-2013, 04:37 PM   #11
rusty76
rusty76's Avatar
Awesome blazer.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-08-2013, 08:35 PM   #12
mm1077
Active Member
mm1077's Avatar
Well got the engine bay detailed pretty well today by masking/painting for about 3hrs. I think the jack and hardware looks pretty good now that it's cleaned up so m gonna leave it.
One of those AC delete covers definitely needs to be in my future, that giant box on the firewall is wearing me out.
Old 08-09-2013, 04:08 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
gotta love duals eh,truck looks great
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-13-2013, 12:11 AM   #14
mm1077
Active Member
mm1077's Avatar
Got some more work done on the blazer over the last couple days. Western chassis 4" drop leafs are on. I didn't find any hits on searching for pics of the drop leafs on a blazer so I'll be sure to post up some once I get everything torqued down and get it out in the daylight. I think it looks good so far but I'm gonna have to remove the bump stops for clearance.
Old 08-13-2013, 12:17 AM   #15
mm1077
Active Member
mm1077's Avatar
Western chassis leafs next to the stockers...stock was 5 leafs and some kind of spacer mount plate between the perch and the springs. WC are 3 leafs. I removed the mount plate and put the leafs straight on the perch...hope that's right this is my first time doing this : )
New u-bolts from right way spring in Tacoma. They made them up in about 10 min.
The second side went way faster than the first after I figured out what I was doing
Old 08-13-2013, 12:27 AM   #16
mm1077
Active Member
mm1077's Avatar
Measured the driver side before @ 30.5"
After was 27.5"
Best pic I could get in the garage. I'm thinking that if I put some air shocks on I should still be able to pull my trailer ok. I'm prob less than an inch off the bumps stops right now, but it looks perfect IMO
Old 08-13-2013, 09:11 AM   #17
Jonboy
Slots go on anything!
You can always trim the bump stops as well. Looks good.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-15-2013, 12:03 AM   #18
mm1077
Active Member
mm1077's Avatar
So I got everything tightened down and got it out of the garage in the light today. I removed the bump stops and I've got maybe a little more than 2" of clearance between the axle and the bump stop mount. I was a little concerned at first, but when I had my wife get in the back nothing even moved. There's hardly any arch to the springs but I'm assuming that's how they're supposed to be; western chassis has a pretty good reputation online for making quality parts anyway.
Now I need to find out what air shocks will work...and start on the front tomorrow.
Old 08-16-2013, 09:54 PM   #19
mm1077
Active Member
mm1077's Avatar
Dropped the front today using some 3" spindles that I got from a friend for 100 bucks and cut off 1.25 coils. I'm not sure if the front needs to go down a little more but I think I'll wait and see how the springs settle in.
Old 08-16-2013, 10:03 PM   #20
mm1077
Active Member
mm1077's Avatar
Couple more pics....2nd pic also shows the grill/emblem that I found and cleaned up a few months ago...
Old 08-16-2013, 10:13 PM   #21
mooseknuckles
mooseknuckles's Avatar
sweet!
mooseknuckles is offline   Reply With Quote
Old 08-17-2013, 11:20 AM   #22
Pro Performance
Pro Performance's Avatar
That is one very clean blazer.... Looks good!
Pro Performance is offline   Reply With Quote
Old 08-17-2013, 11:30 AM   #23
hopped up
hopped up's Avatar
I think the height is right on! Nice blazer!!
hopped up is offline   Reply With Quote
Old 08-17-2013, 01:11 PM   #24
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I was wondering ..... What size tires do you have on it now.....? 15X8 Rally's all the way around ......? I have a gray version of yours and I am trying to decide what to do to it .....!
Very Clean looking .... Drop looks just about right on too. Definitely need to let it settle before you cut anymore though ...!
ksbrktracer is offline   Reply With Quote
Old 08-17-2013, 01:30 PM   #25
mm1077
Active Member
mm1077's Avatar
It has the stock 15x7 rallys on all fours. I'll check the tire size and post it up. I need to change out the tires and am trying to decide between keeping the rallys (and what tire sizes) or to go with a 20" back and 18" front of something else. The 15x7s fit with the 3" spindles but with probably only about a 1/4" (maybe a little more) clearance between the wheel and the cont arm.
