Old 08-08-2013, 06:02 PM   #1
swamp rat
swamp rat's Avatar
bezel lights
Had my dash guage assy out to install a new bezel. After reinstalling I noticed a pigtail and light socket hanging under the dash on the left side of the steeering column that looks like it was plug i
nto the back of the guage assy. Any idea which hole this would plug into?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-08-2013, 06:42 PM   #2
swamp rat
swamp rat's Avatar
Re: bezel lights
Dang ya post from your cell and ya cant edit later...
Had my dash gauge assy out to install a new bezel. After reinstalling I noticed a wire and light socket hanging under the dash on the left side of the steering column that looks like it was plugged into the back of the gauge assy wire was white if i remember correctly. Any idea which hole this would plug into? I don't think i put all the light sockets back into the same hole location, didn't take a pic before hand (lesson learned)
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-08-2013, 06:44 PM   #3
JOJABOY
Re: bezel lights
Sounds like your shift indicator fiber optic hooked to a dash bulb. That bulb can be plugged into any dash socket and the light travels through the fiber optic wire to the pointer on the shifter
JOJABOY is offline   Reply With Quote
Old 08-08-2013, 07:12 PM   #4
swamp rat
swamp rat's Avatar
Re: bezel lights
Fiber optic in the 70's?? Didn't know they had that back then..
I'll get back under the dash tomorrow and trace the wire to see if i can figure out where it goes, still wish would have snapped a pic of the dash assy before i pulled out all the bulb's because there were at least 2 ports with nothing in them. I'm searching now for any info i can find, pictures ect.. Thanks, keep the advice flowing!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-08-2013, 07:19 PM   #5
Mister-B
Re: bezel lights
Fiber optic in the 60's too. My '69 has one, and yes- JoJaboy is correct. That's what it is for.
It is what is lighting up the D on my column
Mister-B is offline   Reply With Quote
Old 08-08-2013, 07:20 PM   #6
JOJABOY
Re: bezel lights
Yeah that's how they got light up to the shift pointer. Does it look like a white wire connected to a brass bracket around the bulb base?
Old 08-08-2013, 07:23 PM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: bezel lights
That fiber optic should go over to the column. To figure out your empty spots shine a small flashlight in them and see what lights up
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-08-2013, 07:28 PM   #8
Ol Blue K20
Re: bezel lights
The one in my truck is black
Dale
Old 08-08-2013, 08:21 PM   #9
swamp rat
swamp rat's Avatar
Re: bezel lights
I appreciate the reply's and i think there may be a brass bracket or something on the back of the socket but i'll have to look at it again, the socket looks to me like it does fit into the dash, i still need to know which port it was plugged into
Does anybody have a pic of how the harness it routed down the steering column? mine has been moved and i do need to get it back in the proper position, i think i'll need to remove the brackets holding it in place... Maybe the white lead is hooked into this harness, i just didn't have time to take a close look befor i left for work.
Thanks again!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
