08-11-2013, 12:31 AM | #1 |
Which Clutch Fork?
Alright guys i picked up a muncie 4 speed for my C10 and was wondering which clutch fork i need to use to make it work..And also will the stock c10 manual linkage work with trans! Thanks!
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
08-11-2013, 07:38 AM | #2 | |
Re: Which Clutch Fork?
the oe clutch fork should be just fine. i'm not sure witch muncie you have but some have fine spline input shafts an unless the clutch disc was changed the fine splines are not gonna fit your disc. when you say "stock c10 linkage" do you mean the colum shifted 3 spd linkage? if so you'll be missing 4th gear. sounds like your gonna want a 4 on the floor shifter. witch requires cutting a hole in the floor.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
08-11-2013, 01:15 PM | #3 | |
