Tremec Swap
Has anyone done a Tremec swap with a big block? Pics?
2WD Jimmy
![]() Join Date: Mar 2005
Re: Tremec Swap
Re: Tremec Swap
Geeze Tom, I go from trying to buy a big block fan shroud off you to seeing what your Tremec swap looks like! LOL
Basically I want to see where your shifter is and if you have headers, how your clutch linkage sits. My truck currently has a small block in it with a Muncie M21. The problem is that I think I might have to move the motor mounts to the forward position to clear the firewall with the valve covers on the 454 and I don't know what that will do to the clutch linkage and the headers. I also want to swap out the original bell housing with the mounts to a traditional aluminum one without the mounts |
2WD Jimmy
Re: Tremec Swap
Ill get the pics tonight.
2WD Jimmy
Re: Tremec Swap
Heres the shifter position, its a McCleod shifter and a Hurst stick
2WD Jimmy
Re: Tremec Swap
Z-bar
2WD Jimmy
Re: Tremec Swap
One more...
Oh... also, the engine is in the stock position. I used tall fabricated valve covers that I trimmed alittle on the drivers side to clear the firewall. Last edited by Tom Vogel; 08-14-2013 at 08:40 AM. |
#8 | |
Re: Tremec Swap
I ordered the Tremec yesterday -The tranny(TKO-600 w/.64 OD) -Slip yoke(Not sure what position my engine is going to be in for the length of the driveshaft yet) -Speedometer cable w/adapter -Reverse light pigtail -Crossmember(flush with the underside of the frame) -Urethane tranny mount -Hardware kit -Hurst mid shift billet conversion installed(to keep the shifter handle away from the bench, like yours) Looks like the headers clear the Z bar with plenty of room. Is the Z bar new on your truck? I might need a new one for my truck because someone butchered it to clear the headers on the small block that's in the truck now. |
motor exploder
Re: Tremec Swap
I have, but I used a McLeod hydraulic throwout bearing, so header clearance wasn't an issue.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
