08-11-2013, 10:01 PM | #1 |
Show me your gas pedal setups for s10 frame swap
Hey all, instead of wading through each build thread to find pics, I was hoping maybe someone could show me your gas pedal setups after doing an s10 frame swap.
I used the original brake pedal/hanger, and the clutch is going to be a whole unit but I am brainstorming for the gas pedal setup. I have the stock s10 pedal and bracket which I think should work fine, but I want some ideas to go by before I start cutting and fabbing. Thanks! Posted via Mobile Device |
08-12-2013, 06:43 PM | #2 |
Re: Show me your gas pedal setups for s10 frame swap
Just trying to keep this post alive. I would also like to see as well. Clay
08-12-2013, 08:39 PM | #3 |
I used a Lokar gas pedal mounted to the floor and a throttle cable from Mr. Gasket.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
08-12-2013, 11:27 PM | #4 |
What he said.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where |
08-21-2013, 01:10 PM | #5 |
Lokar is the way to go!!!
08-21-2013, 05:13 PM | #6 |
As mentioned, the Lokar floor mount works well. it comes with the firewall side bracket and easy hook up with their universal cut to fit cable system. If you are using the S10, it will bolt to the inside and you will just need to fab a bracket on the firewall side to hold the cable housing.
