08-12-2013, 04:40 AM | #1 |
Door striker problem?
Hey fellows found a 67 c-10 a while back that the doors won't lock when shut, locks fine with doors open with key or rod at top of door. Or if I shut the door locked will unlock when it latches. Doors fit and latch well,
Any ideas ?, Thanks |
08-12-2013, 05:19 AM | #2 |
Re: Door striker problem?
Door latches are designed to lock with the key or rod and will not work when closing the door. Your latch is probably just worn. Try pushing in on the door while turning the key.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-12-2013, 08:36 AM | #3 |
I am a Referee of life.
You should try as JimK suggested.Also,open the door and lift on the end.You may find some slop in the hinge this can also cause the door latch to not latch well enough to lock easily.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-13-2013, 04:41 AM | #4 |
Door strikers were replaced by p.o. Seem to be in good condition, door has no sag, aligns and latches very easy and gap around door is close to perfect. The little arm in the latch mechanism won't lock into tumbler when door is shut/ in the striker, will try pushing on door while turning key.
08-13-2013, 07:43 PM | #5 |
Took mine to body shop had bad pins in hinges.
Posted via Mobile Device |
