Old 08-12-2013, 05:06 PM   #1
kjc292
kjc292's Avatar
Interior removal question. panel by feet
not sure of the name but its the panel next to the feet that allows air flow when open. i took all the screws out but that butterfly valve(?)....has a piece that it swivels on. i cant seem to find a way to remove the hinge...
any help would be great. really want to get them out. going to paint the old panels black, get a dash, and wood bezel. might just repaint it blue... havent decided yet.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 08-12-2013, 07:21 PM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Interior removal question. panel by feet
what year is your truck. i painted the kick panels in my '85 crew, & the vent flapper is hinged in the kick panel, will come out with the panel. there is a heavy bead of sealant (butyl?) around the hole which will make it feel like you forgot some bolts
dieseldawg142 is offline   Reply With Quote
Old 08-12-2013, 08:03 PM   #3
kjc292
kjc292's Avatar
It's. 1978 c20. I just don't want to break it.
Old 08-12-2013, 09:37 PM   #4
dieseldawg142
some will come easy, some will fight you all the way, what can i say. i slipped a wonderbar under it from the bottom & just kept pressure on the panel while working the bar around the hole, once the initial bond is broke, it gets easier.
Old 08-12-2013, 09:55 PM   #5
05duramaxhd
They have a sticky gasket be hind it
05duramaxhd is offline   Reply With Quote
Old 08-12-2013, 10:54 PM   #6
kjc292
kjc292's Avatar
Alright. I have the door panel tool. I'll try it tomorrow. Now can you buy that gasket at auto parts stores or is it better to get weather striping at a Home Depot or lowes.
Old 08-12-2013, 11:06 PM   #7
kjc292
kjc292's Avatar
Old 08-12-2013, 10:53 PM   #8
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I used a putty knife when I removed them from my 78. Worked like a charm.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 08-13-2013, 11:05 AM   #9
05duramaxhd
lmc sales the gasket p/n 30-2340
Old 08-13-2013, 01:18 PM   #10
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
The driver side is much harder to get out because of the e-brake pedal, wold recommend pushing the pedal all the way down, then working the panel out, like the other guys said once you the the gasket cut loose it will be alot easier.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
air flow panel, interior panels, interior removal, kicker panels
