Old 08-13-2013, 01:20 PM   #1
jd21476
jd21476's Avatar
Good simple aftermarket A/C
My '73 K20 does not have A/C and I would like to add it. I heard of a kit that sits on the floor as an all in one system and gets wired in to the truck. Anyone know of something like that or any other recommendation?
jd21476 is offline   Reply With Quote
Old 08-13-2013, 02:51 PM   #2
tlawre87
tlawre87's Avatar
Re: Good simple aftermarket A/C
Look up Vintage Air. That sounds like what you are talking about.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 08-13-2013, 04:03 PM   #3
jd21476
jd21476's Avatar
No, that actually goes in the dash. This system is like a kit that just sits on the floor so it can be easily removed and then you just wire it in or plug it in to the cigarette lighter.
Old 08-13-2013, 04:46 PM   #4
tlawre87
tlawre87's Avatar
They sell a kit that goes under the dash too. They also have the kit where you install into the factory vent holes (for the factory look)
http://www.vintageair.com/2012catalo...ge%2048%29.pdf
Aside from this I have no idea. Never heard of one like that, esp the cigarette lighter plug.
Trevor
Old 08-13-2013, 04:51 PM   #5
jd21476
jd21476's Avatar
That is it. Has anyone ever used it?
Old 08-13-2013, 04:54 PM   #6
shok
I don't think that is purely electric tho, you still need to run lines to an AC compressor in the engine compartment.
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 08-13-2013, 06:10 PM   #7
Skunksmash
Skunksmash's Avatar
Have you priced just going with a factory setup? Also, don't be one of those guys that just runs an inverter, and hooks up a window unit. Every time I see one of those in a van I laugh.
Skunksmash is offline   Reply With Quote
Old 08-13-2013, 06:59 PM   #8
shok
I'm actually surprised a finished all electric unit isn't available with a built in inverter. It would take a stout charging system but it seems doable to me and upgrading an alt is less work than installing a compressor and all the other parts.
Old 08-14-2013, 01:50 AM   #9
andrewmp6
The problem with a factory set up the firewall is different ac vs none and all the factory stuff would be used and probably wore out.In the long run a kit like vintage air is cheaper its all brand new and bolts right in.
