Old 08-13-2013, 08:12 PM   #1
0608272c-10
Grounding entire truck
Hey guys where are the ground strap locations on our 72 trucks I'm doing my first frame off and I can't remember where they all go. How many straps am I supposed to use on the engine 350 chevy
0608272c-10 is offline   Reply With Quote
Old 08-13-2013, 08:37 PM   #2
Special-Ed
Special-Ed's Avatar
Re: Grounding entire truck
i dont know the exact answer to where.... but this is what has to happen... motor, chassis and body all 3 need to be grounded together... usually off of the back of block to body then a body to chassis strap.
i always add extra grounds anyways the way i want them to be.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 08-13-2013, 10:45 PM   #3
JonCheun
I just replaced all my old/ missing ground straps on my 1968 C10.
I bought the Ground Strap Kit from VH Coachworks on the Forum
http://67-72chevytrucks.com/vboard/s....php?p=6203495
JonCheun is offline   Reply With Quote
Old 08-14-2013, 06:18 AM   #4
GMCPaul
1 from either side of the valve cover rear hold down bolt to the firewall ( equals 2 wires one for drivers side and 1 for passenger side ),
1 from passenger front frame horn on top of frame to the passenger inner fender. It attaches to the inner fender on the inner edge where as the inner curves downward just as it reaches frame height.
1 from passenger side front cab support on rear side of cab support to the passenger side frame.
1 from passenger side rear frame to 2nd from rear crossmember or far rear crossmember. I've seen them attached to both crossmember's about evenly and I've never found it in the assembly manual so the choice it yours on which crossmember you attach it to on the rear.
The reason you use so many the body is isolated from the frame with rubber bushings and steel bolts are poor conductors of electricity so you can't rely on them to ground the truck for wiring purposes.
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 08-14-2013, 07:27 AM   #5
cdowns
cdowns's Avatar
people really do not understand the concept of grounding
a ground starts at each and every libht bulb and electrical unit and you must b able to follow that ground all the way back to the battery
only reason to never run a ground is ifin u r in a speedboat
Old 08-14-2013, 07:41 AM   #6
MikeyMan
That never gets old
MikeyMan is offline   Reply With Quote
Old 08-14-2013, 06:31 PM   #7
0608272c-10
I'm just new to electrical gmc Paul do you sell a complete kit of everything that I need to ground my truck? If not running inner fenders do I ground my fenders instead?
Old 08-14-2013, 07:42 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Don't over think it too much. All you have to remember is that all components (motor, cab, bed, radiator support) need to be grounded back to battery.
Starting from the negative cable going to the motor. One from motor to cab behind the head (normally drivers side). Install ground strap from bed to frame, frame to bottom of cab, radiator support to frame or battery negative. These are for better loop back to negative on battery. Don't rely on old bolts or painted surfaces to provide a good loop.
Bought all the ground straps at the local auto parts for about $10.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-15-2013, 06:51 AM   #9
GMCPaul
Yes we do sell a factory original ground strap kit that includes all new ground straps and the mounting hardware. You'll find them on the following page of our web site
http://www.gmcpauls.com/Electrical.htm
Part # 210008 67-72 Ground Strap Kit $27.95
In regards to running no inner fender I myself would connect the ground strap to the passenger side of the radiator support to achieve the same grounding as the inner fender provides.
Paul @ GMCPauls
