Motor mount ? (pics)
Can any body tell by the pics if this is set up for V8 or I6 the frame had no engine when I got it Thanks biddaboy
right
My 72 Mounts are the same (350 cid) (would say V-8)
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() |
Designated A-hole!
Looks like the mounts on my 70 with a 350! So my guess is v-8 mounts!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Sorry dude thoes are 6Cly mounts. Yet they will work with a Small block.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Do I have to mount them in different holes for a V8 or are they OK where they are. Putting in 327 and powerglide Thanks biddaboy
They will be fine where they are. You will just not have as much fire wall clearence to the HEI.
i love summertime
i think there is one more hole on each frame rail closer to the front end, cant you move em into those holes? that would make sense to be the v8 position
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
I dont know I am new to this truck but I want to get it right the first time Thanks for any more info you guys can provide this is a great site Biddaboy
Now the others dig........
![]() Join Date: May 2002
Like 72MARIO said, they will be ok and will work for a V8, only the engine will sit farther back, and a bit frther from the radiator, but nothing a fan shroud shoudln't help...heck even with out one over heating isn't a problem.
You could move them up the the V8 position and drill through the lower cross member.....well...thats what my parts truk had done to it.....my girlfreinds dad thought they were V8 mounts...as did I...I yanked em and cleaned them up then compared them to my mounts and such....and put two and two together and came to the conclusion that they were set up oon the V8 pos. and the cross member was drilled. My V8 is in the I6 pos....no problems....but good luck finding a driveshaft....had to have mine made. but no running problems....I just had a bad Crankshaft ![]()
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
67cst....
the V8 mounts are shorter, and that hole you speak of is farther inside the frame than the I6 Below: The red shows the V8 mount holes....the blue X kind of shows Where the I6 mounts would meet the crossmember if moved the the V8 position....and you could drill and bolt....I wouldn't. the green circle May be for, I think, 1 ton 350 mounts or big block mounts....not sure.... I hope I helped.. ![]()
go to a salvage yard and pick up some engine mounts from a truck of our year or even a later model....I think 60 up until 87 will bolt right up. And the pads are cheap at like AutoZone and Oreillys
Watch out for your cornhole !
![]() Join Date: Jun 2003
73-87 mounts are different.
By the way, if you have a short bed, and if you put your V8 in the right V8 position, and run a 700R4 trans, you can use a 81-87 short bed driveshaft without mods. They are everywhere in the junkyards, and it will do away with the 2 piece shaft deal too. |
Hey you guys are great I hate to drag this post on for so long but there is one more thing I forgot to mention, i am using a crossmember out of a 1980 truck in my 69 frame,are the holes in the crossmembers both in the same place for the mounts Thanks again biddaboy
