Old 08-14-2013, 09:30 PM   #1
Lugnutz65
Lugnutz65's Avatar
Wonderful tool! Worth every penny!
I did a search in the TOOL section and really didn't find any useful info about this really cool tool. I bought one today and it works really well.
It's called a needle scaler. It's an air tool that uses hardened steel rods (12 of them on the mini version I bought) to chip away at scaled rust, hardened undercoating and caked on "whatever". It has certain uses, so it's not for everything and won't replace your sander or grinder. For instance, you would not use it to remove paint from a body panel. I find it useful to get into corners where disc grinders and wire wheels can't reach. Plus, it chips stuff off, instead of gumming up your grinding wheel or sandpaper.
I love it. Here are some before and after pics of my first time results. Sorry that one of the before pics is out of focus.
Also, watch the video I linked showing removal of undercoating. Link = https://www.youtube.com/watch?v=Xha4xY-dMrQ
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-14-2013, 10:07 PM   #2
T Smith
T Smith's Avatar
Re: Wonderful tool! Worth every penny!
Man, that made me shudder! I got plenty of time behind those when I rode towboats on the river back in the 70's, chip, prime, paint, chip, prime, paint......
T Smith is offline   Reply With Quote
Old 08-14-2013, 10:17 PM   #3
MailManX2
MailManX2's Avatar
Those work great. A few years ago I used one on a really rusty junk 5.3 engine that I had picked up to use as a mock up motor. It took me about 20 minutes to have all the rust and scale off the block.
I never thought of using it to remove old undercoating. I'll have to give it a try.
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 08-16-2013, 12:29 PM   #4
JWheeler331
JWheeler331's Avatar
That was my thought EXACTLY when I seen this. When I was a little younger and worked on the boats I logged many hours on one of these also. Even wore a hole in some steel toe boots one time because I tried to hide and had it propped up on my steel toe so it would still have the sound so I could catch a little shut eye. After a while this thing did some good damage on the steel toe being there in one spot for so long.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
Old 08-14-2013, 10:51 PM   #5
jimmyjammoto
You can use it to anneal a mig weld on cro-mo tubing also.
jimmyjammoto is offline   Reply With Quote
Old 08-14-2013, 10:58 PM   #6
Lugnutz65
Lugnutz65's Avatar
I need more info please. Not sure I understand. Can you explain?
Old 08-15-2013, 05:54 AM   #7
jimmyjammoto
Sorry, my terms were mixed up..I had meant to say you can use it to peen a weld on cast iron to help relieve stress as the material cools down.
Have seen it used when mig welding trusses on axles where they tie into the pumpkin, if you cant tig it for whatever reason.
I am not a professional welder so do not hold me liable for any damage that may occur from not using the best method of welding for your material.
sorry the thread jack..
Old 08-15-2013, 12:43 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Wow those after photos almost look like the area has been sandblasted. Thanks for sharing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-15-2013, 09:21 PM   #9
Blue666
How much air is needed to run that?
Blue666 is offline   Reply With Quote
Old 08-15-2013, 09:24 PM   #10
Lugnutz65
Lugnutz65's Avatar
My mini needle scaler uses 4cfm at 90 psi.
Old 08-15-2013, 10:53 PM   #11
19666Trucker
19666Trucker's Avatar
I been thinking of getting one, you just sold me one. Thanks for the post.
19666Trucker is offline   Reply With Quote
Old 08-16-2013, 08:29 AM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Adding that to the wish list!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-16-2013, 12:15 PM   #13
timmytimm3
One of the best tools I own. I used it on my entire Jeep frame and front axle knuckles (swapped in a high pinion d30 from a XJ cherokee). My Dad used it on his step side project, and my brother used it on his pickup. Great tool and cheap! Needle scale, wire wheel, wipe, prime, paint.
Don't forget ear protection. They get annoying after a while and of course safety glasses.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 08-16-2013, 12:48 PM   #14
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
So how many pennies does it cost?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-16-2013, 02:33 PM   #15
Lugnutz65
Lugnutz65's Avatar
Regular price at HF in my area is $29 + change. I used a 20% off coupon so it was just under $26 including tax. They have a larger version but I think it'd only be useful for bigger jobs. Replacement rods (needles) run about $5 a set but the originals should last a long time.
Old 08-16-2013, 02:42 PM   #16
joesscamaro
They are great tools! I used them when I was working with a government contractor on humvees and trailors and 7-tons. They are very useful and from my experience with them, the needles will last a long time.
joesscamaro is offline   Reply With Quote
Old 08-16-2013, 06:47 PM   #17
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
A Needle Gun. WorkBoat, DeckHand, I never want to use one of them again Very good tool for the job.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-17-2013, 11:16 AM   #18
FetchMeAPepsi
FetchMeAPepsi's Avatar
OK Lugnutz! You got me. You and Vernski anyway lol. He sent me a link as soon as you posted this and said "Boy you better get you one o' these!" so I did. I didn't see any coupons though. Post it up!
It'll be here next week. I've got my shootin earcups I'll be using and my shootin glasses. We'll see if it's so awesome or if you're just the guy that makes these lookin for job security!
(I'm not excited at all if you can tell!)
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 08-17-2013, 05:16 PM   #19
Lugnutz65
Lugnutz65's Avatar
I bet you didn't watch the video. I saw the video and got so excited that I went outside and tried mine out in the rain (well a drizzle maybe) just to see if it worked as well. Trust me on this one.
Watch this video Link = https://www.youtube.com/watch?v=Xha4xY-dMrQ
Old 08-17-2013, 11:44 AM   #20
Warrens69GMC
Warrens69GMC's Avatar
Coupons come out in the Sunday paper.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-17-2013, 04:19 PM   #21
Wrenchbender Ret
I went out & got one. I have been scraping crud off an old Mopar flathead 6. It is helping a lot.
Wrenchbender Ret is offline   Reply With Quote
Old 08-17-2013, 06:34 PM   #22
cab_01
cab_01's Avatar
Bought one today. Will try it out tomorrow.
cab_01 is offline   Reply With Quote
Old 08-31-2013, 09:24 PM   #23
Lugnutz65
Lugnutz65's Avatar
Well, I thought I should post a video of MY results. Full of glitches and I don't know why. Sorry.
I can't think of a better way to remove undercoating, . . . . . . except maybe someone doing it for me while I take a nap!
Old 09-01-2013, 12:11 AM   #24
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looks good. I'll have to put it on my list.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 09-01-2013, 04:07 AM   #25
lasher78
lasher78's Avatar
gonna make a trip to HF monday ( having a labor day sale ) and im a cheap a@*, hoping can use this thing to clean underside of cab and frame while truck is assembled( cuase i aint taken it apart lol ).
live like you are dying
lasher78 is offline   Reply With Quote
