Old 08-17-2013, 11:15 PM   #1
IntegratedTJ
IntegratedTJ's Avatar
Is this normal..?
So we pulled off the intake manifold and were greeted by this. Not sure if this is normal or what, but it looked bad to me. This gunk (burnt oil?) is just all over the inside, I'm surprised it even ran like this. What does this indicate? Is this normal?? Thanks in advance.
IntegratedTJ is offline   Reply With Quote
Old 08-17-2013, 11:17 PM   #2
Richardwa
Active Member
Re: Is this normal..?
I have seen way worse than that! Usually caused by lack off oil changes
Richardwa is offline   Reply With Quote
Old 08-17-2013, 11:18 PM   #3
IntegratedTJ
Good to hear! Thanks a lot. The truck had been sitting for 8 years in a driveway, so maybe that played a part? Not sure how often the oil was changed before that. Thanks for the quick reply, man. And a good reply to see, too! What a relief!
Old 08-17-2013, 11:28 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
That's the lack of oil changes and the crusty oil that had burned off the choke crossover through the intake. Sadly, I've seen much worse as well. I saw a 305 one time that had the shape of the valve cover molded in in crust around the valves. There was only enough room for the rockers arm to move. It was pouring smoke out of both pipes and pouring oil out both valve cover gaskets because the oil could return and it was running past the valve seals. The guy chipped it all out, sucked it out with a shop vac. The engine stopped smoking and he drove the car for quite a while he was building a new engine with no issues.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-17-2013, 11:36 PM   #5
Lee H
Lee H's Avatar
This is not normal even though lots of folks have seen worst. This crude gets washed though the oiling system wiping out valve guides, rings, bearings, cranks, and cams.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-18-2013, 12:28 AM   #6
67_C-30
67_C-30's Avatar
Agreed - It isn't normal - but it is common. A well maintained engine won't do that...
My trucks
Old 08-18-2013, 12:33 AM   #7
IntegratedTJ
I wouldn't let my engine get like this, guys! Like I said it had been sitting for 8 years and I'm just coming of age. It was just like this when I pulled it out!
Old 08-18-2013, 12:39 AM   #8
67_C-30
67_C-30's Avatar
Yeah, I figured that was the work of a previous owner. I was just saying that was the reason it did it. If you clean it up and keep it changed from here on out, it will probably last you a while.
My trucks
Old 08-18-2013, 12:58 AM   #9
IntegratedTJ
Good to know. I plan on running a full rebuild kit, cleaning the hell out of it, replacing anything that needs replacing. So this problem should be like it was never there. Appreciate all the replies.
Old 08-17-2013, 11:42 PM   #10
Sammy
That bad on top imagine what the oil pan looks like inside.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-17-2013, 11:45 PM   #11
IntegratedTJ
The oil pan is clean as a whistle, actually.
Old 08-18-2013, 12:05 AM   #12
IntegratedTJ
To add on to this.. Could this contribute to bad compression at all?
Old 08-18-2013, 12:14 AM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
Yes, as others have mentioned, lack of oil changes is the root cause of this and it is a result of what happens when oil gets old and breaks down. It turns to this crust from heat which is why you don't see it in the oil pan. Not as hot down there. It is abrasive and will cut the engines life in half and I am sure if you did a side by side test with a well maintained engine, this one would lack compression also.
Clean it as good as you can and run it. I would be preparing a replacement engine if it was mine.
TBONE1964 is offline   Reply With Quote
