![]() Join Date: Aug 2012
Break light issue
Installed new harness push on breaks one lights up other goes out any ideas????
Posted via Mobile Device |
![]() Join Date: Mar 2012
Re: Break light issue
Check your wiring and check your grounds.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
Active Member
![]() Join Date: Jul 2007
As above^.
Install grounds first then check your wiring. Old rusted out bolts or painted over surfaces make for poor grounding and the lights in the back rely on bed to frame to cab to engine to battery ground loop. Get them at local auto parts and install them -Bed to frame. -Cab to frame under the rear of cab. -One behind the drivers side head to cab if there's not one already. -Install one from radiator support to frame. There should be a single wire ground from behind the gauge cluster to the metal part of dash panel. If not, I would install a ground strap there somewhere. After this, you can continue trouble shooting. Believe me, grounding problems will give you lots of headaches.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
brakes sometimes break then are broken brakes
Active Member
So, if brakes that break are broken, how would you fix the break in a broken brake?
