08-20-2013, 02:03 PM | #1 |
Having trouble to find 6 lug 17inch wheels
I have 6 lug 5.5 patern on my 63 c10, I am having real trouble trying to find a good set of wheels. I don't really want to go down the road of standard or vintage wheel, but something that looks a little bit newer.
If any one has some on there truck could you show me a pic or know where you can buy some please let me know Thanks Posted via Mobile Device |
08-20-2013, 02:31 PM | #2 |
Re: Having trouble to find 6 lug 17inch wheels
american racing makes some good looking wheels for not a lot of dollars. I have a crew cab colorado with some 17"AR on it and they look a lot better on the truck than they did in the craigslist ad I bought them from.
colorados have the same bolt pattern and center bore as our 60-66
08-20-2013, 04:38 PM | #3 |
I use to swap rims and tires from my '79 4x4 to the '62s low profile tire to get it in the garage. With all those 4x4s out there someone should have something. I went 18s to get the right size tire. 295/45/18 rear at 28" tall
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-20-2013, 05:18 PM | #4 |
http://www.summitracing.com/search/p...e?PageSize=100
http://static.summitracing.com/globa...1-7883c0_s.jpg 17x8 17x8 17x7 It is a 20x8.5
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 08-20-2013 at 05:24 PM. |
08-20-2013, 05:30 PM | #5 |
17x8 17x8 Summit Racing has more also, some are blaaa.
08-20-2013, 08:02 PM | #6 | |
unless I misread his request LV, he wants a newer style wheel.
08-20-2013, 08:50 PM | #7 |
http://rimzoneonline.com/ I just ordered a set of 16" from them. Hundred bucks cheaper than TireRack.
