08-20-2013, 09:25 PM | #1 |
Hoarding Rusty Objects
Cab-clearance light wiring?
I've been working the last few nights on getting my 85 K20 to have all it's lights working. It had a plow on it, and when the last owner removed the plow lights, he made nothing but the side marker lights and tail lights work. I fixed the headlights, turn signals, etc. All that isn't working is the cab lights on the top of the cab. Where does the wiring for these come down at, and where does it go to? I have looked in a few wiring diagrams, and it's never mentioned. I have no problem running a new circuit if I have to, but I'd like to know where the factory path is before I start tearing into stuff.
1985 Chevrolet K20 Silverado 1994 GMC Yukon Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks |
08-20-2013, 10:37 PM | #2 |
Re: Cab-clearance light wiring?
The wiring should go down the post between the windshield and door and come out just to the left of the gauge cluster. Should have a factory grommet that fits tight in a hole. Power goes to a pin on the side of the pull out headlight switch. If I recall each light has its own ground that clips to the metal of the cab, you'll have to take off each amber light to see the ground.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
08-21-2013, 12:10 AM | #3 | |
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
08-21-2013, 01:36 AM | #4 | |
In the Forgotten far North.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
08-22-2013, 09:57 AM | #5 |
78K & 79C Jimmys
A member here sent me these to set up mine
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-22-2013, 12:24 PM | #6 | |
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
08-25-2013, 02:38 AM | #7 |
Been a while since I was in it, but I believe it's black(-) & white(+)
08-20-2013, 10:50 PM | #8 |
Tuning in as well for my k30
08-22-2013, 03:50 PM | #9 |
Watch out for your cornhole !
Easy way to run the wiring. Also shows the hole under the dash where the wire is supposed to run through.
Posted via Mobile Device |
08-22-2013, 07:02 PM | #10 |
I have a spotlight on that pillar... Wonder how much that affects that... Lol
07-04-2023, 11:39 AM | #11 |
I know this thread is old. I am needing the dimensions to lay it out. I have seen the diagram further up in this post but I can’t read it. Any help would really be appreciated.
07-04-2023, 12:02 PM | #12 |
Here's a couple of threads that may help.
Link: https://67-72chevytrucks.com/vboard/...ght+dimensions Link: http://67-72chevytrucks.com/vboard/s...d.php?t=717781
