Old 08-21-2013, 10:13 AM   #1
charlieatthedisco
Coolant leakage...from...?
This past weekend I replace the front main seal on my 1978 350 c10. All in all it went well no leaks at first when I fired her up last night but shortly I noticed coolant leaking off of the starter! It was dripping from somewhere on the passenger side of the engine and coming down to the starter and dripping off. The only thing I can think of are the two gaskets which looks dry. I just realized I did not put any sealer on the bolts when I reinstalled the water pump, but could this be coming from the weep hole? and why? I should also mention that there was a ton of rust pieces I cleaned out of the water pump when I pulled it off
Chaz
charlieatthedisco is offline   Reply With Quote
Old 08-21-2013, 10:26 AM   #2
truckdude239
truckdude239's Avatar
Re: Coolant leakage...from...?
Have you checked the freeze plugss?theres one right above the starter
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-21-2013, 10:28 AM   #3
charlieatthedisco
I have not, Freeze plugs!? Never heard of that in my life! Where is that located and what is their purpose?
Charlie
Old 08-21-2013, 10:41 AM   #4
frog210
There are 4 on each side v8, they are like a 1.5-2 in metal circle plug
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 08-21-2013, 10:43 AM   #5
charlieatthedisco
A google search told me that the point of the freeze plugs are to pop out if there is too much water in the coolant and the water freezer to prevent damage to the block. These were not leaking before...but I know I have a great water to coolant ratio in there right now, could this be causing them to leak?
Old 08-21-2013, 11:53 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They are called freeze plugs, but that is a misnomer. They are more properly known as core plugs. They are not there for freeze protection. They are there because of the necessity of cleaning all of the sand out of the block casting when its made originally.
Here's the straight story.....
http://en.wikipedia.org/wiki/Core_plug
And, the plugs in your block are 1 5/8 inch size. Available at parts stores for a dollar or so. If you had rusty coolant, you have rusty everything. The core plugs are much thinner than the block and will rust out when subjected to rusty coolant for a while. That's why running straight water in an engine is so harmful to it.
Tx Firefighter is offline   Reply With Quote
