Old 08-21-2013, 01:34 PM   #1
Mownsno
4.5/6 drop and Tire sizes
Is anyone running 255/45/20 front and 295/45/20 rear tires on 20x8.5 and 20x10 wheels. CC69Rat has been very helpful with sizing but I am thinking about running a 45 series instead of 40 series to fill out the wheel well a little bit more. Opinions?
Mownsno is offline   Reply With Quote
Old 08-21-2013, 01:57 PM   #2
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: 4.5/6 drop and Tire sizes
Here are some stats with the same size wheels (width and diameter), but with a little smaller tires.
http://magwa.smugmug.com/Trucks/Stan...1122&k=SGZsV3h
I'd like to go a little bigger, so I'm watching the thread.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-21-2013, 02:30 PM   #3
Mownsno
How much is your truck lowered?
Old 08-21-2013, 02:40 PM   #4
magwakeenercew2jh
Ahhhh! All the stats are listed in the captions on the pics in the link I posted.
The drop set up is captioned on the first pic.
4.5" in front and 6.0" in the rear.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-21-2013, 02:49 PM   #5
CherokeeC10
CherokeeC10's Avatar
I only know this because I am looking at a 4/6 and have done a ton of research on this site so all credit goes to the previous posters on this subject, but seems that 275/40R20x10 w/ 5.5BS and 255/40R20x8.5 w/ 5.25BS is the perfect combo. You can go to a 295 rear but IMO it doesnt gain you a ton and since all trucks are made differently a 275 should be safer from rubbing. Also depends on if you have the wide or narrow rear end. Those specs are for the wide rear later model trucks. Hope this helps.
And when he sees Saint Peter he will tell, "one more soldier reporting sir, for I have spent my time in hell".
CherokeeC10 is offline   Reply With Quote
Old 08-21-2013, 03:33 PM   #6
Mownsno
I have a 72 so yes its the wide rear end. I also have gotten the same B.S. numbers on the wheels. Just seeing if anyone has done this.
Old 08-21-2013, 03:06 PM   #7
67ctener
67ctener's Avatar
I think majority of people (including me) are running 255/40 up front and 295/40 out back. The toyo proxes stii seems to be a pretty popular tire around here. It's great proportion in my opinion with the 4/6 drop
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 08-21-2013, 03:38 PM   #8
Mownsno
Agreed the Toyo's seem to be a popular choice. In fact JD wheel recommended Toyo's. $1694 to my door.
Old 08-21-2013, 03:45 PM   #9
bugmasta
bugmasta's Avatar
same setup here. look and run great!
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 08-21-2013, 04:07 PM   #10
67ctener
67ctener's Avatar
Check out tire crawler. I had my toyos shipped for a little over $700. About 400 cheaper then my local tire store
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
Old 08-21-2013, 04:19 PM   #11
knomadd
knomadd's Avatar
I'm not certain but I think the OP was asking more for the 45 series sidewall vs a 40 series. Will a 295/45R20 fit, or will he need to stick with a 295/40R20? Unfortunately I don't know the answer to that question. I know it's taller and will effect your speedometer, but other than that I don't have any answers. I hope someone else can chime in on whether the 45 series will fit.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-21-2013, 04:22 PM   #12
knomadd
knomadd's Avatar
I think, if 67ctener is right about majority of guys running 40 series rubber, you'll be safer sticking with that, or go with the 275/45 if you want more sidewall and clearance.
-Duane
Old 08-21-2013, 04:42 PM   #13
Mownsno
I agree that's what most people are running. I was looking for more tire height not a taller sidewall or more Clearance.
Old 08-21-2013, 05:29 PM   #14
knomadd
knomadd's Avatar
You probably know this, but just in case, the 40 and 45 numbers are a percentage of the width (295 mm vs 275 mm) so a 295/40R20 is approximately 29.3" tall while a 275/45R20 is approximately 29.75" tall. A 295/45R20 tire is about 30.45" tall.
Check this out... http://www.rimsntires.com/specs.jsp
-Duane
Old 08-21-2013, 05:50 PM   #15
STP67-72
STP67-72's Avatar
I had about a 4.5 drop on my 72 and it buzzed the inner fenders with the taller 45 series on front. I think 4 inch might work.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 08-21-2013, 06:48 PM   #16
C_Ruiz
I ran into the same issue as my friend here.
Had 255/45/20 up front on a 4.5/6 drop.
I now run 255/35/20 up front and 255/45//20 rear. Hope that helps.
C_Ruiz is offline   Reply With Quote
Old 08-21-2013, 08:54 PM   #17
original-71
///Relaxed Atmosphere
original-71's Avatar
What drop do you have
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 08-21-2013, 09:04 PM   #18
original-71
sorry just caught it talking to wife and kids and typing left me blind 40s are perfect IMOive seen them in person and fill fine. you can drop the rear 1/2 to 3/4 also with a drop block to get get that look you want
hector
Old 08-21-2013, 08:51 PM   #19
CC69Rat
CC69Rat's Avatar
45s are possible but I pulled the backspacing back just a tad to make it work.
5 3/8 in the front 255/45/20 on an 8.5" wheel
5 5/8 in the rear 295/45/20 on a 10" wheel
.. yes, its splitting hairs but I thought it looked great. 255/40 is just a little dangerous for potholes and stuff IMO, I just like a little more sidewall.
You could also do 18s, same backspacing and your tire sidewalls would be a bit more meaty. Just a thought. SactoJims truck is awesome and hes running 18s. ( will be a little cheaper too )
Just thinking out loud..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-30-2017, 04:02 PM   #20
CC69Rat
CC69Rat's Avatar
This one has been around for a while, but just in case it might help someone. This is a 20x8.5 up front. 5.25" backspacing. 255/45/20. But this truck also has the 73-87 front member swap.
The rear is a 20x10, 5" backspacing 295/45/20. Narrow housing, 6" drop spring and 3 deg shim
No tailgate in this picture and other stuff still left to go on but this will give you an idea.
Chad
Old 04-30-2017, 07:15 PM   #21
67 cst swb
67 cst swb's Avatar
Good info
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-30-2017, 07:41 PM   #22
jessemthompson
Anyone have opinions on toyo tires?
jessemthompson is offline   Reply With Quote
Old 05-19-2017, 09:17 PM   #23
jessemthompson
255 40 20 up front and 295 40 20 in the rear.
