08-21-2013, 06:47 PM | #1 |
Help Oil leak from Hell
so i cant find this oil leak and i took some pictures of it to show the Pros here it is any help would be awesome
1969 C20 CUSTOM "RUMBLEr" |
08-21-2013, 06:49 PM | #2 |
Re: Help Oil leak from Hell
the Starter
08-21-2013, 07:11 PM | #3 |
Valve covers, intake, oil pressure gauge line/fitting, distributor gasket. Oil leaks from all these areas and it is very difficult to see it until it puddles somewhere. I use a flashlight and a small mirror to look for damp spots. Could also be from the hole on the front boss that it used to hold the fuel pump rod when changing the fuel pump, it dribbles out of there at speed and sprays the lower passenger side of the engine.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-21-2013, 07:12 PM | #4 |
Moderator
Clean the engine real good, then wait and see where the leak is coming from.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-21-2013, 07:16 PM | #5 |
i did yesterday and i cant find it .. i pulled off the starter and cleaned it washed everything down real good and the same thing it ends up in the same 3 spots that i put the picture of
08-21-2013, 07:17 PM | #6 |
rear main? how many miles on the engine?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
08-21-2013, 07:19 PM | #7 |
I'd first check for a plugged PCV valve... wasn't leaking then suddenly starts-- that's my guess..
08-21-2013, 07:14 PM | #8 |
i would show you a puddle but i put a drip pan under it now had to many of them on the driveway lol i checked the valve covers , intake ,oil pressure line , distributor .. didnt start leaking till two weeks ago never leaked before.
08-21-2013, 07:22 PM | #9 |
its one of those damm GM 350 crate motors lol .. so as far as mile on the motor i really have no clue
08-21-2013, 07:31 PM | #10 |
Rear main, Tranny front seal, back of intake at corners, dizzy gasket, Valve covers or pressure gauge. Those are my spots to check first.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
08-21-2013, 07:33 PM | #11 |
what do you check after those lol
08-28-2013, 10:13 PM | #12 |
08-28-2013, 11:36 PM | #13 |
A couple of weird things that could cause a leak are: rear cam plug installed wrong ( or missing ) or block cracked from installing the oil galley plugs with air. I hope neither one is the case. Roy
08-21-2013, 07:34 PM | #14 |
Try cleaning it down with parts wash or brake kleen. Then add UV dye to the oil. Generally ten minutes of running will get a leak source under UV light. But you need good dye, goggles and a good light. The cheap filtered LED lights are about useless.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-21-2013, 07:54 PM | #15 |
If you have cleaned and checked and cleaned and checked..... Then the UV die is the only solution to find the leak.
08-21-2013, 08:01 PM | #16 | ||
"I ain't nobody, dork."
Not sure if the GM crate engines have the bolt holes on the front of the block near the fuel pump. The top hole can leak oil. Put a short bolt in it with some thread sealer.
Gary
08-21-2013, 08:04 PM | #17 |
A great method that I use often is clean it real good, let it cool, then spray the suspect areas in athletes foot spray. Goes on chalk white and really soaks up oil so you have a great contrasting way to see where it's coming from. Just a trick from an old salty tech at work I picked up on.
And when he sees Saint Peter he will tell, "one more soldier reporting sir, for I have spent my time in hell". |
08-30-2013, 02:58 PM | #18 | |
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
08-30-2013, 03:24 PM | #19 |
if its a newer crate engine , the one thing most do not come with is an intake , so check the rear intake seal between the heads , hard to see but easy to wipr with your fingers , rear mains a notorious for leaking if a motor sits for years and is put back into service , the motor will not leak for awhile after being returned to running but after a few miles , usaly less than 100 , and a few heat and cool cycles , it starts pouring out , chevys are bad for this problem
08-27-2013, 10:00 PM | #20 |
I like that last tip! I am going to try it in the future and see how it works.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
08-28-2013, 01:49 PM | #21 |
I would also check around the oil dipstick. I had too much pressure and had to vent other valve cover. The oil pressure was making dipstick move up and leak.
08-30-2013, 03:25 PM | #22 |
I agree with Lee
When they leak from the top this is where it shows up first.
