Gas Tank
Can someone tell me if this from a chevy truck, if so what year and how much would it be worth if anything
thanks Andy ![]() |
Re: Gas Tank
Welcome to the site, there is a lot of info and help on here, and although I my be in on it most of it is in the paint and body section. I have only torn down a few of these trucks and that tank is from those years67-72. Someone with a better eye can be more year spec. Enjoy the site glad to have you here . Jim
Re: Gas Tank
Actually it appears as if it had EEC (evaporative emission control) at one time but someone capped it off. (There should be two short snouts at the base of the filler neck, connected by rubber hose, to (I assume) recirculate fumes back into the tank). If that is the case, then it's a tank from a 1971 to 1972 truck. *If I'm wrong somebody correct me.
Worth? That depends. If someone wants to keep the gas tank located in the cab and behind the seat then it's worth whatever someone will pay. I removed my tank last month, had it renewed (rust cleaned out and coated inside) for $238.00. The stuff is supposed to last forever and by using the old tank I took out any guess work on quality and fitting the old mounting holes. The guy who did the work said my "tank is in excellent shape, other than the slight coating of interior rust and much better than many tanks he's fixed"....so I would think if your tank is solid (not rusted through but even if it was it could be fixed) and someone wanted to use the behind-the-seat tank, then it has value. I cannot guess how much as I don't have experience in such a tank's market value. Last edited by In The Ten Ring; 08-24-2013 at 07:30 PM. |
Re: Gas Tank
Thanks for the replies guys
no snouts at the base was going to post it to my local classified site, but need to know what it's out of and what kind of price i should put on it http://classifieds.pennswoods.net/classifieds/index.cgi |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Gas Tank
This is not a 71-72 gas tank. It looks to be a 60-66 tank that someone added a vent to the sending unit. All 67-72 tanks have sending units that are set in the tank and locked into place with a lock ring. This one is held on with screws. All 67-72 tanks do not use a rubber filler neck. They are 1 piece steel from tank to top. Also the 71-72 emmision tank has a vent on the right side of the tank. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Active Member
![]() Join Date: Jul 2007
Re: Gas Tank
Yeah, and filler neck doesn't look like mine.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
