08-26-2013, 06:18 AM | #1 |
RPM Air Gap
Is anyone running this intake? I'd like to order a 5" air cleaner but I don't know if I'll have the clearance. The engine isn't in the truck yet, so I can't check it myself.
08-26-2013, 06:27 AM | #2 |
Re: RPM Air Gap
Small block? Big block? What carb and will it allow for a drop base air cleaner style? ... Your guess is as good as mine.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
08-26-2013, 06:43 AM | #3 |
Re: RPM Air Gap
I have one on my small block 406 with a 2" spacer and Holley 675cfm and Eddy triangular K-N type air filter. Not sure if this will help as my engine is 2" forward now. Fender wells are still not installed yet so I could remove the air filter and get a measurement for you...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-26-2013, 09:19 AM | #4 |
Re: RPM Air Gap
Are you gonna use it in the winter or colder months. If so your motor will run like crap with a cold intake until it gets up to full operating temperature.
08-26-2013, 10:31 AM | #5 |
Re: RPM Air Gap
Yeah it should fit no prob. I have ran 6" air cleaners with Performer RPM. Just use a drop base and you'll be fine.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
08-26-2013, 05:47 PM | #6 |
Re: RPM Air Gap
mine does
Fuzzy |
08-26-2013, 06:05 PM | #7 |
Formerly- 1972SuperCheyenne
Re: RPM Air Gap
^^I think that air cleaner is almost big enough! ^^
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-26-2013, 09:58 PM | #8 |
Re: RPM Air Gap
Edlelbrock carb, drop base air cleaner. I'm gonna order a 5". Thanks for the input.
08-27-2013, 11:00 AM | #9 |
Re: RPM Air Gap
I used an offset bottom to move the air cleaner forward to clear the firewall.
http://www.summitracing.com/parts/spe-4768/overview/ |
