Another Day, Another Dollar
Hey again,
Did a cab swap on my '78 k20. I re-used my old harness. Now when I pull the headlight switch out my gas gauge drops to below empty and none of the cluster backlights illuminate. I'm guessing I'm having some sort of ground issue here but I could use some direction on where to start. Is there a master cluster ground wire? My other interior lights are working, I still need to pick up a new cab ground strap. To be honest I'm not really sure how the cab is getting negiyie feed but since my other interior lights are working I don't think the the root of the problem. Ps. Same cluster and same wiring harness that was in my old cab. Thanks Spencer Posted via Mobile Device
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
The One And Only !!!
Re: Wtf??
If it worked in the other cab it should work in this one, I'd start with the above...... Sometimes there's no rhyme nor reason when it comes to electrical.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Re: Wtf??
I had one doing the same thing, turned out to be a bad headlight switch.
Re: Wtf??
I'll pick up a strap and a headlight switch tomorrow
Re: Wtf??
I did put in the headlight switch from the new cab and the new cab used to be in a propane truck so the fuel gauge was NFG anyways. Hmm...
Re: Wtf??
Did you maybe miss a ground that ties in at the ground "spider"?
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
78K & 79C Jimmys
Re: Wtf??
there is a spot about a foot from the cluster plug they all go down to one
should be easy to find , if you want to see it look in my 78 below ,when I did the cluster swap Posted via Mobile Device
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Wtf??
The printed circuits on the gauges wear out from age, and can cross circuits at the connector. I'd check that too, if you have contacts lifting or the layers are separating you will need to replace it.
#9 | |
78K & 79C Jimmys
Re: Wtf??
the radio heater anything grounded there seems to go to one "crimp" and it carries as one wire from there Posted via Mobile Device
Re: Wtf??
Do they all just go into a single spade? Any idea off the top of your head if it's a solid black wire or not?
Posted via Mobile Device Ed. I just remembered that I have a harness from a '73 laying around, I'll take a gander at it in the morning.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() Last edited by willett; 08-27-2013 at 11:20 PM. |
Re: Wtf??
Radio heater? What the heck is that?
Re: Wtf??
I think he forgot a comma.
78K & 79C Jimmys
Re: Wtf??
yup I did , can't remember where they all go but I read here it was good to add grounds, I did, I was swapping clusters, and needed to add even another ground,anyway for the small gas gauge.
it stopped my gauge from bouncing too. find a black wire on the cluster plug follow it back and you will find it for sure! Posted via Mobile Device
78K & 79C Jimmys
Re: Wtf??
here it is
#15 |
Re: Wtf??
thanks bro!
I haven't had any time to mess with it since I made this thread and I'm heading out of town this weekend, but hopefully by Tuesday I'll have er' back in the shop. I have a feeling that there's a ground dangling somewhere. On a completely unrelated topic Motornut, how did you lose 3 trucks while parked?
#16 | |
78K & 79C Jimmys
Re: Wtf??
now i just buy shorter trucks...seems to be working! the 78 and 87 were hit parked at work the 88 in front of the house
#17 |
GoatLube Experss
![]() Join Date: Oct 2009
Re: Wtf??
naturally,,, smaller target, harder to hit ! makes since to me.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#18 | |
78K & 79C Jimmys
Re: Wtf??
(next morning,78 Jimmys further up) and now i got this great pic when somebody wants to know where the door wires go lol
#19 |
Re: Wtf??
Finally got some more time to mess around with it.
Attached a body ground - nothing Tried a headlight switch - no difference Started monkeying with the cluster harness - the plug into the back of the cluster wasn't in all the way. D'oh!! Problem solved! Now I have to find the .69 amp draw. How the heck do I pull glass fuses without breaking them?!?! Posted via Mobile Device
#20 | |
78K & 79C Jimmys
Re: Wtf??
#21 |
Re: Wtf??
That was the first thing I tried, but some of them are seized in there and end up breaking in half if I can get an end to budge. Guess I just gotta take it sloooooooooow
#22 | |
78K & 79C Jimmys
Re: Wtf??
20s were hard to find at a Canadian tire store,was surprised at that all kinds of newer, but a couple of mixed packs with 1 -20 Posted via Mobile Device
#23 |
Re: Wtf??
Lol I shredded the 20a radio fuse today and all I could find was a 15 and a 30, I went with the 15. Should be good, I run a power amp anyways
#24 |
Re: Wtf??
So the under-the-dash light draws about .67 amps :|
I knew the dome light wasn't connected but I forgot about that one. What I did learn is that the constant power on my tach draws 3-4 ma though for some reason. :s Posted via Mobile Device
