Old 08-27-2013, 11:58 PM   #1
Aarons72
Aarons72's Avatar
How do you not chip painted bumpers with bolts?
Going to put on painted bumpers soon. The ones I took off were crazy chipped all around every bumper bolt...what are you guys doing to keep your bolts from messing up your painted or powder coated bumpers?
Im thinking like little rubber o rings or hose gaskets or something?
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 08-28-2013, 12:50 AM   #2
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: How do you not chip painted bumpers with bolts?
Mine look perfect. Of course, I just put 'em on today.
But the '72 had painted bumpers, too. And I never had any cracking or chipping where the bumper bolts met the bumper.
I think probably the reason...or the way to go...is to make sure the carriage bolts fits squarely (of course), you adjust the brackets so
and the head of the bolt takes even pressure all the way around. In other words, lays flat as you tighten it.
Possibly, I've had good luck because I put the bumpers on both times when the paint and clear coats were both dry...
...but not fully "cured". But I'm not sure about that.
I do know that I didn't torque them down with an air hammer. Don't know how many pounds. Generous torque, not 200ftlbs.
I saved the serious torque for bolts that connect the brackets to the frame.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 08-28-2013, 05:17 AM   #3
cdowns
cdowns's Avatar
run the nuts up and down the threads to make sure there r no obstructions b4 putting into the bumpa holes
Old 08-28-2013, 12:14 PM   #4
Aarons72
Aarons72's Avatar
ok sounds good guys.
Aaron Anderson
*1962 Nova
Old 08-28-2013, 12:41 PM   #5
bbadfred
bbadfred
bbadfred's Avatar
My solution was mount and adjust fit, weld them in, grind heads off and prep the bumper and then paint it.
bbadfred is offline   Reply With Quote
Old 08-28-2013, 02:13 PM   #6
FL71C10
Nice, job, your own homemade smoothie bumper!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-28-2013, 08:22 PM   #7
Tinkermc
Do not use air tools to install. Use a hand ratchet and go very slowly
Tinkermc is offline   Reply With Quote
Old 08-28-2013, 10:40 PM   #8
slow-1
slow-1's Avatar
I would think that if they are properly prepped and painted, they won't chip just putting them on...with hand tools anyway.
I bet most chips happen when the bumper bumps something.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
