Old 08-28-2013, 08:48 AM   #1
tommys72
tommys72's Avatar
tach dash in
It's in and looks good, I have to get a new circuit for it though, none of the gauges work after I put put back in and only one light lights up
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-28-2013, 10:14 AM   #2
tommys72
tommys72's Avatar
Re: tach dash in
Can some of you guys gimme a pic of where you have your tachs plugged in on the fuse panel please
Thanks in advance
Old 08-28-2013, 10:20 AM   #3
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: tach dash in
That tach sure looks good! I want one for my 1968 C10. I just found a full set of gauges (no tach) in a junkyard and I want them, but am not sure if $50 is a good price.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 08-28-2013, 10:31 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach dash in
I would not pay to much over $25.00 unless it is really nice. Will they refund your money if the gauges are not working? You will need to invest in new bulbs also.
TBONE1964 is offline   Reply With Quote
Old 08-28-2013, 10:22 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach dash in
That is looking good sir. You might want to just double check the ground and the plug in again if you have not yet. If that does not work, try a separate ground wire directly to the tin on the back of the cluster to a known good ground.
Old 08-28-2013, 10:49 AM   #6
tommys72
tommys72's Avatar
Re: tach dash in
Thanks buddy, she's a work in progress
Old 08-28-2013, 12:55 PM   #7
tommys72
tommys72's Avatar
Re: tach dash in
Ok fellas, I got the tach to work and the one dash light, but nothing works now. .. what could it be?
Old 08-28-2013, 01:03 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach dash in
I am not 100% sure on this but I think you should have a gauge fuse in the fuse panel. Have you tried to wiggle the electrical connector behind the cluster while the truck is running to see if anything happens? If it all worked before then it has to be something like a connection problem, ground, or bad fuse.
Which one dash light works? never mind, i read your prior post. Speedo light correct? Does the bright light indicator or the turn signal indicators work?
Old 08-28-2013, 10:20 AM   #9
jjzepplin
jjzepplin's Avatar
Re: tach dash in
Does the tach work? And congrats... only 9,277 miles on your truck-sweet.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-28-2013, 10:48 AM   #10
tommys72
tommys72's Avatar
Re: tach dash in
Nothing works right now, except the light bulb for the speedo. That's the original gauge, I have to assume thats 109,277
Old 08-28-2013, 10:39 AM   #11
71K20chevy
71K20chevy's Avatar
Re: tach dash in
I got the repo harness from Classic Parts, I think it was $20.
It's got the plug for the back of the tach, the one that plugs into ign. unfused on the fuse panel, and the plug that runs through the firewall to the coil.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-28-2013, 02:21 PM   #12
71K20chevy
71K20chevy's Avatar
Re: tach dash in
While the circuit board doesn't look the greatest, I don't see any obvious spots.
You might try cleaning up the contacts and seeing if that helps.
71 K20
64 GMC mud truck
Old 08-28-2013, 02:36 PM   #13
tommys72
tommys72's Avatar
Re: tach dash in
I cleaned up everything a little bit when I had it apart just now. Putting it back together right now. I do have a test light...but I didnt even think to use it....
Old 08-29-2013, 09:20 AM   #14
tommys72
tommys72's Avatar
Re: tach dash in
So I took it back apart cleaned it up a bit, made sure everything was good and tight. Now the tach, speedo, oil pressure gauge and all dash lights work. Just fuel, battery, and temp gauges aren't working. Gonna try some fuses today as my last guess, or a new printed circuit. Any one have any other guesses?
Old 08-29-2013, 09:38 AM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
Re: tach dash in
Sounds like you are on the right track Tom. All of those gauges you mention should be powered by the gauge fuse in the fuse block.
Use your test light and make sure the fuse has power on both sides. You will need to have the ignition in the on position to check this.
Old 08-29-2013, 10:06 AM   #16
tommys72
tommys72's Avatar
Re: tach dash in
Ok I'll do that. Thanks Tom
Old 08-29-2013, 10:11 AM   #17
71K20chevy
71K20chevy's Avatar
Re: tach dash in
Make sure the wire didn't get disconnected at the fuel sending unit!
71 K20
64 GMC mud truck
Old 08-29-2013, 10:32 AM   #18
tommys72
tommys72's Avatar
Re: tach dash in
I'll get a look at it, didn't know about it coming undone
Old 08-29-2013, 12:04 PM   #19
tommys72
tommys72's Avatar
Re: tach dash in
I give up for now. .. replaced some fuses, made sure again the connection was in good. Only thing I can figure now is its the printed circuit. Guess I'll have to give a new one a try now
Old 08-29-2013, 07:54 PM   #20
Andy4639
Old member
Andy4639's Avatar
Wink Re: tach dash in
Looking at this picture it looks like the upper 2 are 3 connections are missing and maybe some lower ones to. The circuit is cut off and looks like it may not be making contact with the plug once inserted.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-29-2013, 08:23 PM   #21
tommys72
tommys72's Avatar
Re: tach dash in
That was my final guess, I ordered a new one which I'm guessing will fix the problem
