Starter wiring help
I bought a mini high torque starter but have a points distrib. I have 2 wires that connect to the R side on the old starter solenoid and one to the S side. I know I have to put a diode in the wire that was connected to the R side but which wire??? Why would there be 2 wires? Any help is appreciated.
Posted via Mobile Device |
Re: Starter wiring help
The purple wire comes from the ign. switch when turned to start. It connects to the S term. The other wires go to the R term. They feed the coil through a resister & bypass the resister in the start position for more voltage to the coil. You do not need a diode.
#3 | |
Posted via Mobile Device Posted via Mobile Device |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
If you Have two terminals on the starter S and R then Wrench is correct, but if you only have one terminal on the mini starter you will have to connect all three wires to the same terminal in order to get the solenoid to engage and to get the 12 volt feed wire and the resistance wire to feed the coil. You will have to install the diode in line with the two wires that used to go to the R terminal, to keep the ignition wire that goes to the coil from back feeding the terminal on the mini starter and keeping the solenoid engaged or trying to engage.
Furthurmore you will have to install the diode on a short wire off the starter terminal and then join the two wires together on the cathode side of the diode or the wire from the key switch will feed the starter solenoid anytime the ignition is on. It might be easier to connect the resistance wire directly to the coil positive terminal and run a single wire from the starter terminal to the coil positive terminal with the diode inline.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks guys, Hopefully I'll have time this weekend to install it!
