Old 09-01-2013, 03:55 PM   #1
K10Scottsdale78
K10Scottsdale78's Avatar
Blower motor will not shut off completely
Whenever I slide the top switch to the "off" position, and the bottom switch to "cold", the truck still cranks out hot air through the floor vent right by the shifter, and makes it unbearable to drive on warmer days. I do need a new temp. control assembly because my fan switch will not mount since the screw mounts are broken. Thus my fan speed is always on low (all the way down).
Will a new assembly allow it to stop blowing hot air all the time? The last time I had it apart I lubricated the crap out of the control wires, and still will not stop blowing hot air. If this doesnt work, am I looking at more repairs so the blower will completely shut off when I want it to?
-1978 K10 Scottsdale LWB
400 SBC 4 spd muncie SM465 ("heavy chevy")
-2002 Toyota Celica GT
5spd (gas saving daily driver)
-1969 Pontiac Firebird (post-college project car)
K10Scottsdale78 is offline   Reply With Quote
Old 09-01-2013, 05:16 PM   #2
wilkin250r
wilkin250r's Avatar
Re: Blower motor will not shut off completely
The blower motor is on any time the ignition is on, to provide ventilation in the cab. It's never really "off". I've known a few people that didn't like this aspect, so they just cut the low-speed wire.
The temperature control, however, is another story. It shouldn't be hot air all the time, time to check the cables, blend doors, and vacuum lines.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-01-2013, 05:23 PM   #3
Unca
Most people install a simple on off switch to fix this issue. Cut wire, install switch in line. Done deal.
Unca is offline   Reply With Quote
Old 09-01-2013, 09:20 PM   #4
walkerb
walkerb's Avatar
I unplug mine. Though I only drive my 74 in the summer
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-02-2013, 07:10 AM   #5
Hertzdaddy
Two things that applied in my situation. I have a 73 Jimmy so its similar.
First, I got a 4 way blower switch from a later truck and left the low speed position unhooked so it now is "off."
Second, the rubber seal at the cowl that seals when the hood is down was missing. This let hot engine compartment air into the fresh air ducts which is where the blower gets its "cool" air from. I could not get it to blow cold until I replaced the seal. In fact, since I had a cowl hood too, I had to seal up the back edge of the hood itself to keep the air from coming through the vents. Now the hot air goes out of the hood where its supposed too and things are nice and cool in the truck.
You might check the condition of the rubber hood seal. Also, the temp control slider moves a little door so you should be able to see (and hear) that move as well.
Hertzdaddy is offline   Reply With Quote
Old 09-02-2013, 05:03 PM   #6
K10Scottsdale78
I like that idea of a 4 way switch, so I will probably order one.
I do hear the temp control door when I move the switch, but if you could, could you point out where that seal exactly is? I just want to make sure I get the right part that I need.
Old 09-02-2013, 06:57 PM   #7
Hertzdaddy
It's the gasket seal on top of the cowl (black strip of rubber) in this pic:
If its missing the hot air from the engine bay runs through the gap and into the cowl vent area and down to the blower fan intake. Once the engines is hot it can make things nice and toasty in the truck.
Old 09-03-2013, 12:25 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
i've read it's called "power venting" to bring in fresh air
i cut the brown wire on the 78(three speed),and the 79 (4 speed)
so both have off
also the defrost/floor control has three holes for ajustment
giving1/3 up all the time
all up or down
or 1/3 down all the time
need to have the air box apart to ajust....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-04-2013, 08:39 AM   #9
K10Scottsdale78
Mine definatley does not have that, so that could be my problem. Where can I get one? LMC?
Old 09-03-2013, 01:18 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
Early on people complained of exhaust fumes in the cab so gm "fixed" it by having the motor always on. Although In my 86 I can take the switch to "off" position and the fan shuts off. Otherwise it's always going
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-04-2013, 10:55 AM   #11
Rich84
Rich84's Avatar
I'm missing that also...No fumes coming in even with no heater box installed..LOL
Rich84 is offline   Reply With Quote
Old 09-04-2013, 04:12 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
my 78 hood seal is off too since i painted it red.....lost it in the parts dept lol
I get some fumes,sometimes out of the turn signal hole lol
but thats blowby..or my undercoating....and it's cheaper then cigarettes!
John
