09-02-2013, 08:44 AM | #1 |
Static Drop Spring Question
I want to do a down-and-dirty (read: CHEAP) drop just to make blu look a bit cooler. Long term plans are spindles or bags but with it needing so much other stuff right now and my budget already destroyed, I just need to get it lower.
Can I simply install the mcgaughy's 2" drop front and 4 or 5" drop rear springs? (I don't want to cut springs, as inexpensive as these ones seem to be) Will I be able to get any kind of alignment without dropped spindles or have any clearance issues in the back? I expect I'll need to get a shock relocator kit for the rear (it needs new shocks as well so I'll just get a set of AC Delcos for now). Its not a daily driver so I can live with losing some ride quality. Seems to be the least expensive way for me to at least get out of the nosebleed seats for now. Any issues? Thanks!
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
09-02-2013, 08:51 AM | #2 |
67-72 parts collector,…
Re: Static Drop Spring Question
2" front and 5" rear is a good plan if you plan on using drop spindles later.
But the front will be higher now. You will also need an adjustable rear track bar for the rear. I suggest www.earlyclassic.com for parts.
09-02-2013, 09:45 AM | #3 | |
I assume you mean the adjustable panhard bar? Thanks!
09-02-2013, 10:04 AM | #4 |
yes and yes.
09-02-2013, 10:28 AM | #5 |
From my study's of the subject, I am going to do a 2/4 drop on mine...all of the pictures I've seen of 2/4 drops the truck sits level...with a 2/5, the rear is gonna be lower than the front.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
09-02-2013, 06:12 PM | #6 | |
nuts! well heck with that!
Thanks guys.
09-05-2013, 10:41 AM | #7 |
Grandpa in the rustmobile...
Cut 1 coil in the front springs
Install a drop block (2") in the rear from forum vendor ($60)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-06-2013, 10:49 AM | #8 |
Sounds inexpensive enough... what will that give me, a 2"/2" for now?
09-05-2013, 11:34 AM | #9 |
09-15-2013, 02:28 AM | #10 |
Yes, 2" block in the rear and roughly 2" in the front. Wished I had a better pic I shot that after the truck was sitting for 8 months while I was..gone...
I have nicer pix on flat concrete but its 'stock' height in those.
09-23-2013, 09:26 PM | #11 |
2" spring and 2" spindle and in my opinion sits way too high. I think I got something weird just hope it's not the spindle Posted via Mobile Device
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
