Old 09-02-2013, 12:35 PM   #1
jimboh247
jimboh247's Avatar
1985 305 vs. 1986 305
Besides the 1 piece real seal, the center bolt valve covers, and the different bolt angle on the intake, is there any other differences between the '85 305, and the '86 305?
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 09-02-2013, 12:53 PM   #2
Jake Wade
Jake Wade's Avatar
Re: 1985 305 vs. 1986 305
86 should have the 1 pc rear main seal but the same perimeter valve cover as the 85. Intake bolt pattern the same also.
87 is when the change to centerbolt covers.
Jake Wade is offline   Reply With Quote
Old 09-02-2013, 01:07 PM   #3
jimboh247
jimboh247's Avatar
The guy says it's an 86, out of a Camaro. But it has the center bolt heads, and what appears to be the old style intake bolt angle.
Whether it's an 86 or 87, is the cam the same between 85, 86 and 87? That is, if the 87 is not a roller cam.
Old 09-02-2013, 01:18 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Depends on what 305 we are talking about. The truck 305 or passenger car 305
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-04-2013, 07:36 PM   #5
jimboh247
jimboh247's Avatar
Well, I pulled the intake, and it is at least an 87, due to the roller cam.
What I want to know:
Will 85 or earlier heads bolt on to the 87 block if I use the earlier intake?
Can I ditch the roller cam and go with a cam from an earlier (non-roller) motor?
All I really need is the short block.
'85 SWB Silverado
Old 09-04-2013, 08:45 PM   #6
Jake Wade
Jake Wade's Avatar
Yes to all your questions. I would take advantage of that roller ready block,myself
Old 09-04-2013, 09:18 PM   #7
07XCSBZ71
07XCSBZ71's Avatar
You'll have to use the 86-up one piece rear main flywheel/flexplate. I agree with Jake, I would use the roller setup. Free upgrade.
07XCSBZ71 is offline   Reply With Quote
Old 09-04-2013, 10:24 PM   #8
jimboh247
jimboh247's Avatar
Thanks for the heads up on the flexplate. I was fixin' to toss it on the scrap pile.
I have a new flat tappet cam, but I guess I could sell it and get a roller cam. I'm going to pull the heads and oil pan to check everything inside out.
'85 SWB Silverado
Old 09-06-2013, 09:59 AM   #9
jimboh247
jimboh247's Avatar
Another question:
Does the factory cam use a different cam gear on the distributor?
'85 SWB Silverado
Old 09-06-2013, 03:07 PM   #10
INSIDIOUS '86
Originally Posted by jimboh247 View Post
Another question:
A flat tappet cam can take a normal iron distributor gear. Roller cams are steel and will eat through those quickly so you will have to get a melonized distributor gear to run
