91 SWB 383
header ???????????
what header fit r trucks . i want a shorty header . my truck is drop 4/5 . i know a f-body fits but not sure what years . i want to go buy a set this weekend unless someone has set for sale .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
Actually, it's a G body header, not an F-body header. I'll let someone else chime in here, who actually has that Header. (Ryan, or someone else...)
91 SWB 383
ok thanks . that why i wanted to check before i order lol
BAD BOW-Silverado XST
The shorty header you are looking for is for a SB Chevelle. 64-87 shorty if I remember correctly.
A 3/4 length header for chevelles fits between & doesn't hang below truck framerails. Big blocks are the same as well (I'm using Sanderson BB3's, which are 3/4 length for Chevelles).
These will be better than manifolds, but will fall short of full equal length headers for the guy searching for max performance.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-07-2003 at 05:25 PM. |
LED King
Edlebrock started making shorty headers for our trucks recently.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
i have a 4 /6 drop on my 78 with full lenghth hedmen headers . no problem with clearance. Well you want to slow down on speed bumps.
Get some pics of those full length headmans in relation to the bottom of the frame rail.
With a 4/6 drop 4" in the front i got 4" of ground clearance with full length headers. The top of the collector sits right with the bottom of the framerail. I also have collector flange stiffners for added support(( for grounding out and sealing). I recomend flange stiffners and alumunuim gaskets . I also like a crossover h -pipe with flanges for easy tranny and exhaust removel ( balances flow and improves lowend torque). hedmen headers are usually the cheapest on the market. I never had a problem with them.
Scoti, can you get some pics of those headers.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
91 SWB 383
i have a h-pipe in it now . 3" exh with flows on it
I'll try & bring the digi cam home tomorrow. There's no freakin' way full length's would fit under my crap. The bottom of the header better be even w/the bottom of my framerail or it will be a quick, certain death.
What do you guys . . .... oh never mind, I'll start a new thread.
kevin if you have a jegs catalogue, look at the dynomax ceramic coated headers, then look at part number 289-86118, this is the shorty myslef and others are using, it fits perfiect.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Could someone please post some pics of the Chevelle headers in our trucks?
![]() Summit has them for $230.
#15 |
91 SWB 383
thanks man . i was hoping u would Q in . it the 64-87 chevelle ,67-81 camaro sbc shorty 229.99 .. i'll order some tonight . how r the seats
#16 |
the seats are great man, i love em
c&c here is a pic of the chevelle shorties on my old motor ![]()
#17 |
91 SWB 383
thanks again man . u going to the show today in deton
#18 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
SCOTI, I have the Sanderson Headers for my BBC too. http://www.captkaoscustoms.com/images/sandersonhdrs.jpg
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#19 |
Pretty. Mine are just bare since they don't recommend them to be coated during initial engine start-up. I'll get them coated eventually.
#20 |
I have a spare set of "break-in" headers for that.
