09-04-2013, 08:12 PM | #1 |
6.2 diesel Suburban to flatbed conversion
Hello this is my first post. I am converting a suburban I bought as scrap into a flatbed truck so I can pass inspection. My experience doing anything like this is working at a auto salvage yard for a year and a half, so I am worried about the reconstruction half. I drove the suburban for a little over a week after I gutted the burnt interior and changed the front doors steering column gauges and put a windshield in it. It got very good mileage (about 24) so I got a cucv cab to put on the frame. I started dismantling the truck Monday and now I'm about to put the cab on after paint but I'm not sure what to for rear cab mounts. I would rather use u bolts than weld on the frame, I don't have a welder
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
09-04-2013, 08:16 PM | #2 |
Re: 6.2 diesel Suburban to flatbed conversion
09-04-2013, 08:17 PM | #3 |
09-04-2013, 08:21 PM | #4 |
This is the paint scheme I'm going to use
09-04-2013, 08:36 PM | #5 |
Why not just use cab mounts to mount the cab? Can you just move the Suburban body mounts and use them? Or find some truck body mounts from the junk yard? After thinking for half a minute this might be a bigger undertaking than you planned. I think suburbans have a different width frame, someone who knows better can clarify if I am wrong. And i don't know about frame heights being the same truck to suburban (where the frame contours up and down along the profile.
09-04-2013, 08:46 PM | #6 |
The frame is the same as a long wheelbase pickup except 4 inches shorter wheelbase. I know that the front cab mounts are the same but the rears are about a foot and a half further back. I guess that is the best option, to chop off two brackets and weld them on further towards the front
09-04-2013, 09:49 PM | #7 | |
Just use 3/8" grade 8 bolts. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-05-2013, 08:47 PM | #8 |
Agree with keith. If you are off a bit you can drill new holes... Welding is a bigger pain i the a$$ if ya miss
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
09-10-2013, 07:50 PM | #9 |
It's been a slow week, but I'm about to start mounting the cab. I was wondering, what is the best most trustable way to join two wires together and insulate it?
09-10-2013, 08:14 PM | #10 |
I just twist the wires together and wrap them in electrical tape.
Few things in life will make you look stupider than putting a dollar sign after a number. |
09-10-2013, 08:35 PM | #11 |
Another Day, Another Dollar
Whaaaaat?!? NO!
Use heat shrink and butt connectors at minimum! Solder and heat shrink if you don't want headaches Down the road Posted via Mobile Device
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
09-11-2013, 12:32 AM | #12 |
Best way is to solder them and use shrink tubing.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
09-12-2013, 09:34 AM | #13 |
x2 Butt connectors are aluminum and the dissimilar metals will promote corrosion.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
09-12-2013, 03:16 PM | #14 |
Getting closer on the truck. Wiring, lowering the body more then ill have to do brakes, mounts, steering column, interior. I'm considering making the hole in the firewall wider because the cucv seemed to have fewer plugs than the suburban. Then using insulating tape to close the gap.
