2002 5.3 need help troubleshooting
I have a wrecked Silverado, has been sitting for a while(4 yrs ,bought it is way). Just replaced fuel pump. Getting gas to fuel rails. Engine turns over normally. Does not fire.
When I spray ether into the throttle body it does fire, almost like a back fire. Just so u know, the front clip has been removed. This make easy access to the engine but there were a couple of grounds I had to attach. All the needed fuses appear to be good. My thoughts are maybe clogged injectors, but am also pondering that not ALL would be completely closed... Seems I would have some sputtering... Toss some ideas/suggestions out, please Rich Posted via Mobile Device
meowMEOWmeowMEOW
Re: 2002 5.3 need help troubleshooting
corroded plugs, worn wires, dead coil, coil pack ground not attached, clogged injectors or bad gas. FPR diagphram broken/not holding pressure.
Vacuum leak, internal pcm ground bad, or any of the wires not hooked up during the wreck or clip removal. How did it wreck and did it run/drive after the wreck? Need more info.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I was told it clipped a power pole, turned up on the drivers side with the engine still running.. Not sure if it was ran any after the wreck.
I do not have a fuel pressure gauge, but there is pressure at Schrader valve on fuel rail. those are good things to take a look at for possible problems. I do have a spare fuel rail from another truck, may swap that out... Don't think that will take very long Posted via Mobile Device
Oh, forgot to mention, all fresh gas
I pulled a couple of plugs, looked good but were dry... I was expecting them to be wet
![]() Join Date: Sep 2005
These trucks are bad about the injectors stinking shut pull them and soak them in seafoam or replace them if it runs off started fluid the sign side is fine
with the weekend here (yeah), i plan to work on this til i find the problem... i am like a kid in a candy store.... just got the new fuel pump in place and it seems to be working...
maybe i can remove the fuel rail next...... do you guys sometimes find that ALL of the injectors are blocked?
#8 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
thatz basically what i wanted to hear..... the fuel rail is my next step.... just didnt want to tear into that if there was a more likely culprit.. thanks guys
I had to replace 3 of my injectors and clean the rest and my motor only set 6 months. I think it would just make sense for everybody to at least clean them as you install the motor.
What do you guys suggest? what works best ? i understand i should not expose the o ring(to the cleaner)... any other precautions?
replace the oring an oring set is only like 5 buxs i soak mine in seafoam
seafoam it is... thank you.
INDIAN113, do you recall if yours sputtered or fired any prior to cleaning your injectors?
(at initial startup)
#15 |
#16 |
meowMEOWmeowMEOW
if you google it there is a way to use a modded 12v source to trigger the injectors while in the solution
#17 |
thanks, good idea.... i think i have stumbled across such stories in the past... funneee thing is..... didnt need them at the time, but do now :-).......
i just knew when i hooked up the new fuel pump, put on the MAF... hit the key.... it was gonna "bust off" and purr like a kitten...... oh well.... maybe after i fix a couple (8 inj) gobblins.
#18 |
Is there some sort of safety cut off that is triggered when these trucks roll over???
Yes, i know the prior owner said it was running while turned on its side at the time of the wreck......just thinking of possibilities.. What do you guys think? Posted via Mobile Device
#19 |
There's a fuel pump cut off but that's all I know of
#20 |
meowMEOWmeowMEOW
The ecm will cut power to the fuel pump if there is a rollover, or at least it *should*.
Now, I have no idea what the ecm sees in a case like that. I doubt there is some "lock" on the fuel system, but I could be misguided.
#21 |
Ok, it is early Saturday morn, time to get "cracking". As the guys on wheeler dealers say
#22 |
meowMEOWmeowMEOW
up at 6 am on a saturday? haha
*as I roll out of bed and check the forums at noon ![]()
#23 |
Ok guys, I didn't get as much done yesterday as I had hoped. House a/c is acting up. Had to chase parts for that (no major supply stores open on Saturday)
I did get the inline factory gas filter changed out. I bought some chemicals to clean the injectors with. Hope to jump on that today. But first I hope to check for fire at the spark plugs. Maybe I can get the wife to come turn the key while I watch for spark. Posted via Mobile Device
#24 |
There's nothing in the PCM that will shut off the fuel in a roll over. Fords have inertia switches but GMs do not. If the car is up side down there won't be any fuel to the pump and once whats in the lines runs out the engine will stop, and when the engine stops theres no crank sigbal and the PCM will shut off the pump.
I would get the injectors out and get them soaking since you may want them to soak for a while. I usually let them soak overnight. With them out tou can pull the fuel pump relay so you don't spray gas all over and then check for spark. But since you said the plugs were dry, my bet is the injectors. Posted via Mobile Device
#25 |
Ls1nova. Thanks for the input. I did verify I have spark. Then proceeded to remove the fuel rail, with everything still hooked up, I turned the engine over... Nothing came out of any of the injectors on pass side...Since I was excited, I proceeded to remove the wire and retainer clip from the front injector. Ok, you guys know what happens next, right? Yes, you guessed it. When I pulled the injector out of the fuel rail...instant fine spray of gas right into my eyes.
Ok that is behind me. I have a question. I have taken the injectors out. My question is how exactly have u guys soaked / cleaned your injectors. I have taken the lower o ring seal off. As of now, I have the lower/spray nozzle soaking in cleaner compound. I guess my question is, will this do the job? Should I immerse the complete injector into the cleaner. Shoul d I pour compound into the top of injector.? Your input is appreciated, since the sooner I get these cleaned the sooner I get hear this thing run Rich Posted via Mobile Device
