09-07-2013, 12:40 AM | #1 |
Blower motor won't work on high
What is the likely culprit?
1972 K5 Blazer Cheyenne 1966 L72 Corvette Convertible 2016 GMC Yukon Denali |
09-07-2013, 03:09 AM | #2 |
Old member
Re: Blower motor won't work on high
Is it AC/heater are just heat?
If it's ac check the fan switch and relay in that order. I just went through all this. When the switch is on try touching the fan switch under the dash. Don't grab it but just tap it to see if it's nasty hot. If so replace it. They are cheap. If not really hot look at the relay under the dash for the ac.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-07-2013, 03:16 AM | #3 |
Its a Truck Thing......
Switch contact or resistor is bad....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
