On the water pump for a 5.3 vortec, which of the two is the outlet for the heather, how is the water moving??
Thanks |
![]() Join Date: Sep 2005
Re: Water pump outlet to heather
botgh of the 2 outlets are for the heater core i had 2 different size hoses on my heater core so they would only fit one way
Thanks truckdude, but one has to be the supply and the other the return, this engine is in a 66 truck with the 5.3 and a vintage air conditioning
Posted via Mobile Device |
#4 | |
![]() Join Date: Feb 2004
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Okay I put mine into my 71 so one port on my heater core was larger and matched the port on the pump and same for the other one I haven't run it yet
Sorry but my engine compartment is dirty from Georgia clay and Florida sand. Obviously one is feed. One is return. big one = return little one = feed 2005 suburban z71 with 5.3 Posted via Mobile Device
Ed will be known as the Tiger Woods of the integration business Last edited by Special-Ed; 09-10-2013 at 03:03 PM. |
#7 | |
Of chorse my phone wont let me post the image but if you google ls engine flow (images) the second one is a diagram and the back or smaller port is feed.
Thank you all
im not sure... i have a replacement water pump and i think my casting is bad. i have little to no heat in the truck.... not a big issue when im in florida... but i froze my azz off when i went to chicago for the holidays to hang out with my kids... its pissing me off as well... i eat about 1/2 gallon every 6 months of anti freeze... i find no leaks,(die black light) holds pressure, no exhaust fumes bubbling in coolant, no signs on plugs... but every once in a while i smell steaming coolant... thinking it may be a dodgy pressure cap.
or it could be seeping into the intake somehow and leaning out the fuel mixture but still being burned... i dont know enough about my engine to know off the top of my head every coolant port inside the motor and where they may leak. i was the guy at the factory that dealt with quad 4's and the 3.4 twin dual ohd motors... and other assorted items for PMD... the return seems like it needs to be ported to the other side of the tstat for flow to actually happen...
Ed will be known as the Tiger Woods of the integration business Last edited by Special-Ed; 09-10-2013 at 03:33 PM. |
#12 | |
the return from the heater core goes directly back to the tstat housing/water pump... it does not go back to the over flow pressure tank...
Ed will be known as the Tiger Woods of the integration business |
*** That's interesting ***
Might be interpretive, but perhaps that diagram just indicats a tee in the heater line where the pressure tank connects. I don't interpret this as meaning the heater hose goes straight to the tank.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#14 | |
#15 |
Yes, that is what I was looking for, i did a search like Robznob11 suggested and found a diagram.
Thanks Posted via Mobile Device |
#16 |
i have a nurse called heather she is hot but i've never seen her outlets
#17 |
Here is the picture I found
#18 |
Old member
Are u guys all using the pressure tank (surge tank) in the swaps on 67-72 trucks that is posted above.?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 |
I'm not using it
#20 |
meowMEOWmeowMEOW
That is designed for sealed radiators that use a remote surge tank (kinda like using the ps pumps that have a remote resevoir). If your radiator has a cap with a pressure rating, then your don't need that. The idea is that it keeps some extra fluid and give the fluid a place to go under. It also helps keep a full radiator since it hold extra fluid that can drain into the rad if it gets low.
Most of us have a regular capped radiator. You fill the rad, and run an overflow so it has a safe place to dump if it overheats. We would have to manually add coolant or water if the rad got low, but you also don't have to place and plumb an extra tank underhood.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#21 |
Old member
OK then I'm good to go I have a over flow tank already!
