09-09-2013, 06:53 PM | #1 |
Front Brake Plumbing.. Post up ideas and pics
Looking for help / suggestions in plumbing front brakes. I have a 54 Chev with a TCI Mustang II front end, and a 79 Trans Am disc brake rear on a 4 link coil over suspension. I'm running a fuel injected 355 ( Holley Stealth ram), and need to rely on the ability to slow down. I'd like to use through frame fittings on the front brakes. I'm also wondering about routing options to the passenger side. If anyone has pictures of their pluming I would really appreciate it.
09-09-2013, 09:33 PM | #2 |
Re: Front Brake Plumbing.. Post up ideas and pics
for more ideas, you might go to Barnes and noble, and look in transportation section, and there will be a book on brakes. the section on hot rods is small in the book, but has a few nice pics.
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
09-10-2013, 12:47 AM | #3 |
09-10-2013, 02:40 AM | #4 |
Here is one i did on a Falcon using the Mll front end...
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 |
09-10-2013, 02:59 AM | #5 |
This one on a '55 chevy using Mll front end
09-10-2013, 09:51 AM | #6 |
These are the front brake lines on my 57 with NoLimit suspension
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
09-10-2013, 12:59 PM | #7 |
Awesome... I love to admire the skill and dedication to our hobby/vocation. Getting some really good info . Thank you all so much.. hope it helps someone else as well. keep em coming!
09-10-2013, 03:03 PM | #8 |
i'd recommend a straight line tube kit from inline tube or any other vendor.
straight line tube runs better and looks better on the frame compared to coil stock imo supplement it with some short straight pieces for ease of install and minimal flaring ss lines require a good flare tool, steel lines you can get away with almost any double flare tool
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-21-2013, 10:41 PM | #9 |
Another question. There are 2 different options for flares for the fittings. 45° or AN 37°. Im leaning towards the 37° because they arent a double flare.
DV8 |
09-21-2013, 10:55 PM | #10 |
37 are for AN fitting only... 45 is the standard for steel line.
09-25-2013, 07:19 PM | #11 |
this is what im looking at... http://inlinetube.com/Street%20Rod/-ANSets.htm
Id really like to use the thru frame fittings on the front. well i guess i should read first. AN flares on cars are for garage and trailer queens.... 45° it is.. dv8 |
09-25-2013, 07:35 PM | #12 |
Here are photos of mine front and rear, pretty simple. I used preflared lines with fittings from NAPA and braided lines from Russell. Only had to flare about 4 ends.
09-25-2013, 08:48 PM | #13 |
i used a similar kit from inline tube
straight line ss kit w/ double flare supplemented with a few short lines from local auto parts store
11-29-2013, 10:02 PM | #14 |
I don't deal with In-Line Tube. Screw me once, shame on you... I deal with The Right Stuff, Columbus, Ohio. They even told me the length of their largest shipping box and cut my stainless lines to that length. No custom charge. They just charged me the normal per-foot price.
Here are a few shots from my '55 2nd series layout: Master cylinder/power brake area: Manual proportioning valve close-up: VW hydraulic pressure switch & 2 lb. residual valve: Driver's rear, near the axle. Note that I have no hard line on the axle housing. I ran hoses from the rear calipers to the frame: Driver's front:
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
