5 lug to 6 lug swap.... new universal?
Have a couple of questions about swapping in a 72 axle into my 68. I tried searching for about 20 minutes using a bunch of combinations of key words with no results.
Will I need a new universal? Can I use the brake lines from the 6 lug axle? Anybody want to buy a 6 lug axle? (Joking) |
Re: 5 lug to 6 lug swap.... new universal?
Anybody
Posted via Mobile Device |
member #16
![]() Join Date: Dec 1999
Hard too say on the U joint. Chevy used different sizes for different applications. The brake lines are longer on a 72 v 68 axle. Also the flex hose is mounted different. Probably have to install 72 axle and adapt to fit.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
![]() Join Date: May 2011
I used a wide 70 rear axle on my 69, the yoke I am running is the same yoke from the 69. There was no difference for me. I bought a braided steel Brake kit from Inline Tube and told them what I was doing and they used the 69 brake line (longer!) and then the added the newer distribution box to fit right up to the existing lines.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
No driveshaft or u joint changes needed.
![]() Join Date: Nov 2012
I just completed this swap. I used the '67 brake lines, and the '67 u-joint swapped just fine. I went to taller gears,(Better M.P.G.'s) and disc brakes, including power steering, and I can tell you it's a whole new truck. Down right fun to drive now. I changed spindles up front, and replaced all the ball joints. (Required) I also used the '72 steering assembly instead of the '67. (It needs the '72 tie rod ends) I also swapped steering box and the sway bar and added new sway bushings. Major difference! I cut one coil out of the front springs and it lowered it just right, (for my taste.
![]() I just noticed your header says 5 lug to 6, and I did the opposite, but I hope this still helps you. ![]()
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
