09-10-2013, 05:00 PM | #1 |
"Trucks with Class"
Clutch Fan-SB-Restored
Cleaned, blasted, painted OEM SB correct thermal fan. All water pumps have two bolt patterns. This is the smaller one. Included is the matching pulley. Should be OEM correct for earlier motors like 68 back. Works fine with later engines with single pulley and it is the right size for SB fan shrouds.
$60 + $15 S/H lower US. Also have two new USA-made thermal clutches, like the one in the pics, for use on fans with this small pattern---$40 + $10 S/H. Call for them on here. thanks, frank Last edited by PICKMUP; 05-01-2014 at 08:35 PM. |
01-15-2014, 05:43 PM | #2 |
"Trucks with Class"
Re: Clutch Fan-SB-Restored
Still got this one left! Very nice and it comes with the matching WP pulley.
$75 shipped in CONUS. |
01-16-2014, 02:20 PM | #3 |
"Trucks with Class"
This is the "correct" GM truck fan for our SBs. It is not some other car, wrong year, etc... that might fit.
04-24-2014, 01:57 PM | #4 |
"Trucks with Class"
...and can sell the fan (less pulley) & clutch for $60 shipped...
04-24-2014, 05:03 PM | #5 |
Will this fit a 350 RamJet motor . . . . with the long neck water pump and single pulley for the alternator?
04-25-2014, 12:17 AM | #6 |
"Trucks with Class"
I don't have a clue...fits stock 283s &327s and others with the small bolt pattern.
04-30-2014, 11:35 PM | #7 |
I don't know to much about the fans. Didn't they make a heavy duty model? I have a 350 and want to do some towing? If you don't know I guess I will have to ask around, my trucks almost back on the road and I need one.
05-01-2014, 01:50 PM | #8 |
"Trucks with Class"
The HD/AC fans were 7-blade...
05-02-2014, 12:04 AM | #9 |
That seems to be the general consensus on this forum. However, not all of them were 7 blade. At least one, my 69 3/4 350 with factory A/C and 4 row radiator, came new with a 5 blade clutch fan. It has never been replaced. I don't know if mine was a fluke or if the chance to 7 blade fans was later than my early December,1968, build.
05-01-2014, 08:29 PM | #10 |
low n' slo
the usa made fans are with a clutch..or is just a fan?
im looking for something to replace my flex a lite fan. my shroud from lmc measures about 19" i think... let me know thanks
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-01-2014, 08:38 PM | #11 |
"Trucks with Class"
I have new "thermal clutches" (without the fans). That is why they are much cheaper than the one shown. I corrected the wording to make it clearer. thanks, frank
05-01-2014, 08:40 PM | #12 |
low n' slo
can you measure the from blade to blade? i need to see if this will fit
05-02-2014, 11:19 AM | #13 | |
"Trucks with Class"
The fan is 17"................................................ |
05-01-2014, 08:57 PM | #14 |
Okay thank you for the information. I will pass on it
07-29-2014, 02:50 PM | #15 |
"Trucks with Class"
SOLD the fan...
Two new clutches are still available for early ('68 & older) fans. |
