Spindles too big?
I'll cut and paste from my build thread:
Moving right along, grabbed the front hub and tried to install onto my new spindles, the inner bearing won't slide over the spindle on ether spindle, i test fit all the bearings and seals on the old spindle so didn't even give it a second thought.... Put the rotor/hub back on my work bench, grabbed one of my old spindles and she popped right into place, sigh. I grabbed my calipers and measured about .001 difference, the newer spindle was of course bigger. So 2 steps forward and 4 steps back again.. I'll have to inspect the new spindles a bit closer, but curious what your thoughts would be to using a strip of emery cloth and trying to polish it down a little? I'll check into this a little closer later, i really hate the thought of having to pull an inner bearing to remeasure it as i'll waste a seal in the process.. I might pull a spindle tomorrow and try and install it on the bench like i did with the old one today. While i'm on this subject, the Prevailing Loc Nuts are suppose to be replaced each time, has anyone here reused them?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#2 | |
![]() Join Date: Jul 2012
Re: Spindles too big?
As far as the locknuts go, I always replace locknuts and lock washers when they are on applications such as spindles, steering components, or rotating components subject to motion/vibrations, like drive shaft u-joint hardware etc. I know there are specs for lock nut hardware, but it will take some research. Generally if they still have a certain amount of "run-on" torque, they are still serviceable and can be used. Unless you want to check each one, and new ones don't cost to much, the most conservative answer would be to replaced them. Hope this helps.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 Last edited by JPBrecheisen; 09-13-2013 at 10:35 AM. Reason: forgot to ad some information |
Thanks for the reply!
Yea, it looked like it was starting but only about 1/8" or so, then hard to get back off. This is one time that i really wish a had a lath and some soft jaws, its a lot easier to spin it with the emery cloth in hand..
#4 | |
Just look for an impression mark where it is binding to help identifiy where the high spots are. I think you'll be just fine once you do that. Like I said, I'm not and expert, but that what I had to do, and it wasn't ever and issue. If the nuts aren't too pricey or hard to get, I'd just put some new ones on and you won't ever have to worry about after you get it all together. Jonathon
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
Thanks for the help, i hope to have then done and the hubs mounted by this weekend!
I took one of the hubs back off and remeasured it, its looking like about .0005 will do the trick on the first one. Was hoping to find some 1000 grit X 1" wide strips of emery cloth today but the finest i found was 320.. will try the local auto paint store tomorrow. I think tonight i may try a piece of scotch brite first and see if i can get it with that.
