09-14-2013, 08:34 PM | #1 |
largest tire
whats the largest tire that you can get off the rear on a static dropped 49. running boards are about 6" off ground. have 4link with 275/60 tires. I cant get them off without unbolting the coilovers. wheel 8'/41/2 offset
09-15-2013, 07:33 AM | #2 |
Re: largest tire
tap,tap,tap. is this thing on?
09-15-2013, 01:20 PM | #3 |
Re: largest tire
I have 255-60-15 on the back of mine on 8 inch rims on a Nova rear axle and have about a half inch clearance inside and out. That is with no tubs but the inside of the tires are known to rub the bed on hard corners if I am not careful.
09-15-2013, 01:26 PM | #4 |
Re: largest tire
im trying to find a tire I can get off my truck in case of a flat on the side of the road. I don't want to take the coilovers loose on the side of the rode. but I don't want the tinies tire either
09-15-2013, 03:14 PM | #5 |
Re: largest tire
I've carried two jacks in my truck for years. A little trolly jack to raise it up far enough to get a bottle jack under the frame rail to jack it up high enough to get the tire off the ground while letting the axle drop down as far as the shock will let it. If i have a flat on the front I have to stick a bottle jack under the frame and lift the front of the truck enough to put the trolly jack under the frame. One does what one has to do but most of the time these days we don't have a lot of flats anyhow. My 2000 Cadillac has 156K on it and I don't think the spare has ever been mounted on the car.
09-15-2013, 05:54 PM | #6 | |
Re: largest tire
10-05-2014, 08:45 PM | #7 |
Re: largest tire
Jackson what's the rear housing dimension? any chance to go tighter? What setup are you running up front?
10-05-2014, 08:54 PM | #8 |
Re: largest tire
s10 blazer 4wd rear gbody frame clip , 2'' s10 dropped spindles 5" wheel 3" backspace 205/70 tire. I think I can get a 215/70 on rear with 6" wheel with 2" backspace and get thay off without problems
10-05-2014, 10:39 PM | #9 |
Re: largest tire
You are a long way from the first guy who has had to take a shock or spring loose to drop the axle far enough for the tire to clear on a custom rig. If the truck looks r/ight to you with the tire/wheel combo you have I'd say just be prepared for having a flat with the needed wrenches along . I'm thinking there is one side of my truck I can't get the tire off without a bit of a hassle. I know I can't do it with the jack under the axle.
10-06-2014, 06:44 PM | #10 |
Re: largest tire
10-06-2014, 07:37 PM | #11 |
Re: largest tire
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
10-07-2014, 05:20 AM | #12 |
Re: largest tire
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
