Old 09-14-2013, 11:28 PM   #1
mgchevyparts
mgchevyparts's Avatar
Q's about replacement outer rockers
I bought a repop outer rocker for my 71. There is no verticle metal for the weatherstrip to attach to. This is a vertical metal strip about 3/8" tall that the door weatherstripping push's onto. How do I get this piece. I think it should be part of the outer rocker.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 09-14-2013, 11:31 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Q's about replacement outer rockers
Yes, it should be part of the replacement rocker. Can you post some pic's of what you have? Is the original rocker still intact on the truck?
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-14-2013, 11:32 PM   #3
mgchevyparts
I was just looking at Brothers, maybe the inner rocker has this vertical strip, they call it an extension??
Old 09-15-2013, 05:35 AM   #4
JimKshortstep4x4
Replacement rockers should have the "lip" on it for the seal to attach to. There are rocker "skins" that used to be available without the lip that are made to fit over the existing rocker. The ones that I have seen are very thin.
Here is a picture of a rocker which has the lip.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-15-2013, 12:55 PM   #5
mgchevyparts
The outer rocker I bought is not a skin and it does not have the vertical "lip". In looking over the vendors sites it appears that the inner rocker might have it as they refer to it includes the "extension" but the pics are not large or clear enough to make that determination. I guess I'll just buy a inner rocker and see what I get.
Old 09-15-2013, 04:55 PM   #6
72bowtiestepper
Thumbs up Re: Q's about replacement outer rockers
Jim
That is a REAL nice resto job that you did on your cab.....wish mine was that far along !
72bowtiestepper is offline   Reply With Quote
Old 09-15-2013, 06:58 PM   #7
JimKshortstep4x4
72bowtiestepper,
Thanks! That is an older picture as the truck is completed and a real pleasure to drive.
Good luck on your truck!
Jim
Old 09-16-2013, 06:54 PM   #8
mgchevyparts
looked at the orig rocker I cut out and it does have the vertical piece as part of it. So now the question is:
Does anyone know a particular brand that has this correctly as orig did? The Dynacorn one does not have it.
Old 09-15-2013, 01:05 PM   #9
Orange Crate
Orange Crate's Avatar
TBone and JimK are correct, the outer rocker should have the lip for the door seal. I just got done replacing both sides of my cab inner and outer rockers, so I can confirm their answer to your question also.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 09-15-2013, 01:45 PM   #10
mgchevyparts
The one I bought has a dii sticker, that's Dynacorn, right? Do you know a specific brand that does have the vertical lip?
Old 09-17-2013, 05:10 AM   #11
GMCPaul
There are slip on rockers designed to go over the originals and they have no lip on them. Then there are full rockers that have the lip and are just like OEM. If you bought a OEM style rocker and received one with no lip they shipped you a slip on rocker panel. DII, Tri-Plus, and more make both the slip on version and OEM version. In my opinion the OEM version by Tri-Plus is best so that's the brand we carry.
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 09-17-2013, 06:44 PM   #12
mgchevyparts
Paul @ GMCPauls
Looked at your website and nothing listed that I could find.
Old 09-17-2013, 06:11 AM   #13
71sierragrande
Petroleum User
71sierragrande's Avatar
I have one with the lip that I'm pretty sure came from LMC. But, IMO it's a cheap POS and I wouldn't recommend it
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
