Old 09-15-2013, 01:07 AM   #1
Thebrownturd
Finally test drove the 70
After getting the hood aligned, grill back on, and getting the lights and indicators working. I was able to drive it. The only problem is that I almost had it floored and I couldn't get her over 55. No strange noises or smoke. I got an hei, new carburetor, and water pump but, I hadn't had any problems before. Does anyone have any idea where to start?
Thebrownturd is offline   Reply With Quote
Old 09-15-2013, 04:39 AM   #2
lha1992
lha1992's Avatar
Re: Finally test drove the 70
Well whats your rear end gear ratio setup? 3speed, 4speed tranny? OD?
lha1992 is offline   Reply With Quote
Old 09-15-2013, 08:37 AM   #3
HSRACER
HSRACER's Avatar
Always check to see if your carb is opening all the way. Have someone sit inside and floor it with the engine not running and see if there is still any movement in the throttle at the carb. This has happened to me as I was on the floor and the carb was only have open!
Also check you timing if it is retarded it could slow you way down. Good luck.
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 09-15-2013, 09:52 AM   #4
El Campo
El Campo's Avatar
Is it up shifting? I had a turbo 400 stick in a low gear once and had the same problem.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-15-2013, 02:06 PM   #5
Thebrownturd
It a 3 speed 3/4 ton with 4:10 gear ratio. I no it's not ment for speed but I need to get it to go highway speeds.
Old 09-15-2013, 02:12 PM   #6
Thebrownturd
That might be what's wrong. I messed around and found out it was stuck in 4 hi. Not sure how to it out though
Old 09-15-2013, 05:59 PM   #7
El Campo
El Campo's Avatar
Linkage?
Hook em Horns!!!
