09-15-2013, 10:37 PM | #1 |
rear disc brakes
Will the backing flang off a 96 impala rear disc brakes fit on a 85 c10. ... I know the kits are cheap. .. I just like the fact that I can just get everything I need at one of the local parts yard. ..
Posted via Mobile Device |
09-15-2013, 11:25 PM | #2 |
Re: rear disc brakes
I just bought a caprice rear yesterday. No, the backing plates will not fit without modifications. The truck uses a larger housing end than the car. There aren't any in the local salvage yard here. I looked all over for this one.....
09-16-2013, 09:16 AM | #3 |
Ok thaks... guess I'll have to order or get a bracket made. .
09-16-2013, 02:45 PM | #4 |
Happy to be here
Just order a kit from Capt Fab in our Vendor marketplace. I understand your desire to use over the counter parts, but the brackets are not a "wear item" . Once they are installed you shouldnt ever have to worry about them again.
09-16-2013, 05:31 PM | #5 |
Enlighten us o'wise Squarebody Gurus. I really don't understand that well. I've seen a few "kits" for rear disc brakes go for around $500. What's this bracket that's needed? Once we install the bracket, then we can install disc brakes from an impala? If so, what years are recommended?
09-16-2013, 05:40 PM | #6 |
a set of weld-on brackets for stock cars can achieve the same end. if a person has a mind to do so. I'm a more out of the box thinker then some. but that's how we put disc brake rears on rock crawling jeeps. brackets. calipers and hardware off a mid to late 80's midsize GM. banjo bolts, lines and pads gtg... there are some calipers w provisions for an emergency brake as well... some web research can tell you part numbers n costs and I'm sure somewhere has a video showing the task.
09-16-2013, 08:15 PM | #7 | |
09-17-2013, 02:43 AM | #8 |
If you want a e brake http://67-72chevytrucks.com/vboard/s...d.php?t=382633 the impala ones http://www.67-72chevytrucks.com/vboa...77#post3259777
09-19-2013, 12:34 AM | #9 |
And that for putting impala front disc on the rear ..
09-19-2013, 02:54 AM | #10 |
Both kits use impala rear rotors the camaro caliper kit has a e brake the impala kit don't have a e brake.
09-19-2013, 05:31 AM | #11 |
There are few guys that have put tha whole B-body axle under there...tha width is different..but i don't think by that much
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
09-21-2013, 02:10 AM | #12 |
So what would be better just get the bracket or jus change the whole differential out and can some what tell me what year exactly you need if u wanna get the brackets orfrom what car exaclty i really wanna do it after reading this
09-21-2013, 03:22 AM | #13 |
The rear end swap is not a bolt in you'll have to cut off all the mount tabs and weld on spring perches and shock mounts,Not sure if you have to mess with the drive shaft or not.On the two bracket kits read the post in them they list what rotors and calipers you need to have.
