power steering conversion 1970 C10 ??
can someone tell me what id need and need to do to convert my truck to power steering? its a 6cyl w/2 speed auto. thanks for any help!
![]() Join Date: Mar 2012
Re: power steering conversion 1970 C10 ??
buy the correct power steering steering box for that year, Napa sells them then get the hoses and pump and a mounting bracket, is not hard to do, look at summit for the pump and mounting bracket or a junk yard
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
I am a Referee of life.
When shopping for the pump,brackets and pulleys,make sure you get them all from the same vehicle.There are differences in the brackets and pulleys that can be a nightmare to match up.The box may be something you want to investigate further.If you use a 67-72 box,it will have approximately 4 1/2 turns lock to lock,which makes the steering feel (for lack of a better term)"mushy".The later box is 3 1/2 turns LtL. and has more "positive" feedback or roadfeel.Use a pitman arm for PS from the year of truck and it all just bolts up.Then use a string and adjust to the shortest setting.Wrap the string and measue it's length and get a belt.Fill the PS pump and start the truck with it on jackstands.Turn the wheel LtL several times,shutting off and refilling between times.Once all the bubbles disappear,you should have most of the air bled from the system.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Yep, not enough stress can be put on getting all the parts from the same vehicle...so many combos to match if you dont! This fact has been drilled into my head from this forum and Ive read about the headaches trying to match pulleys. PS pump, water pump, harmonic balancer and anything the belts wrap around GET!!! Oh ya....for the steering box grab the rag joint too...its a different size from the manual box. As for me....I have the stuff...just tryin to find the time to do it! Good luck and keep us posted!
![]() Join Date: Oct 2009
Panel and 68iron are giving you good advice regarding getting everything off of the same truck. That said, it will probably be much easier to find a set of brackets from a car, as I think there were a lot more 6 cyl cars produced with PS than trucks. I pulled my brackets from a Nova, found a correct 2 groove water pump pulley after digging through a pile of them for about 10 min, and picked up a gear from a local guy that had one laying around. You shouldn't have to worry about changing your harmonic balancer....at least I didn't....just make sure the spacing on the belt grooves on the harmonic balancer are the same as your truck on the vehicle you are pulling it from.
The bad thing is that most people now know the value of these setups, so they probably won't be cheap. They pop up on the board every once in a while. There are always several sets available on EBay. It's not that hard to piece together, just be patient! Posted via Mobile Device
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
#6 | |
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
I have my brackets, I have a feeling I will have a problem matching up as I dont have all pulleys from the same vehicle. I need to get the rag joint.
![]() Join Date: Nov 2001
I'd suggest installing a sway bar up front. If not already , goes hand & hand with P S .
1)pump pulleys 2)harmonic balancer and pulleys 3)the pump/alternator brackets 4)pump pulley |
You can see the choke cable towards the back....and yes...it is a dirty engine! |
All the PS parts came off a 79 Nova with non integrated exhaust head.
