09-22-2013, 03:28 PM | #1 |
brake help fast
I Have a 1971 c20 pickup truck 2wd. It has a dana axle but I am not sure what size rear drums and shoes I need and I don't have to time take it all apart and look. I was hoping someone might be able to help me out on this. Thanks!
09-22-2013, 05:34 PM | #2 |
425hp409
Re: brake help fast
There are two sizes of rear shoes, depending on whether you have leaf or coil springs.
For coil you should have 11 5/32 X 2 3/4" Napa part # UP248R For leaf you should have 12 X 2/12", Napa part # UP419R Posted via Mobile Device
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
09-22-2013, 08:10 PM | #3 | |
Re: brake help fast
Ok thank you and would you happen to know what the drum size I need for those as well? I have leaf springs |
09-22-2013, 08:24 PM | #4 | |
Re: brake help fast
I have a C20 with coil springs and my drums cleaned up with very little metal removal. It's not easy to find a shop that can do this. An automotive drum lathe won't do it and a shop that does big trucks will tell you the drum is too small for their equipment. I found a shop in Houston that does equipment like forklifts. Both drums $130.
Gale Gorman '54 3100 '67 C20 stepside |
09-22-2013, 08:32 PM | #5 | |
Re: brake help fast
09-22-2013, 11:58 PM | #6 | |
425hp409
Re: brake help fast
09-23-2013, 09:50 AM | #7 |
Re: brake help fast
That wasn't what I found. The problem was the hub. This is a C20.
09-23-2013, 06:46 PM | #8 |
Re: brake help fast
Does anyone know where I can get a diagram or video online of how to remove the drum for this truck?
09-23-2013, 09:27 PM | #9 |
Re: brake help fast
This might help with the job maybe not with your question..
http://67-72chevytrucks.com/vboard/s...d.php?t=200268
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-23-2013, 09:33 PM | #10 |
Re: brake help fast
