Old 09-24-2013, 10:11 PM   #1
1980c-10 mybaby
1980c-10 mybaby's Avatar
motor questions
Who has the most random motor in there truck? im talking not ls or 383 im talking like maybe a Japanese motor possibly
1980c-10 mybaby
1980c-10 mybaby is offline   Reply With Quote
Old 09-24-2013, 11:09 PM   #2
1980c-10 mybaby
Re: motor questions
Heres my toughts...
I currently have an rb20det out of a 91 Nissan skyline its on a full stand alone engine management which means I can swap vehicles easily.
Here come the problems with this swap
need electric fuel pump (easy fix)
motor mounts( just need to make some)
new drive shaft(easy enough)
the main part factory rb20 tranmissions aren't the best but heres the gravy
Ive got a proto type bellhousing to mate my motor to the tko series transmission which can handle more power and weight than my factory transmission and runs off the pressure plate and clutch disc of the mustang or Camaro at that point
I know this is a long shot and basically it would be different and useless to tow with but I want something different and ive got 90% of that I need to get it done. I just need a truck and than to swap everything over honestly
the truck will go full air ride once done and ill cut weight where I can to bring the total weight of the vehicle down
let me know what you guys think
1980c-10 mybaby
Old 09-26-2013, 02:54 AM   #3
DREAMER1
DREAMER1's Avatar
Re: motor questions
Know what I think? !... keep me posted....just gotta see how this turns out. And you're right, you have the most oddball motor in our trucks
DREAMER1 is offline   Reply With Quote
Old 09-26-2013, 05:52 AM   #4
79Betty
79Betty's Avatar
Re: motor questions
Different... Yea... Do it!!!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-26-2013, 08:30 AM   #5
eray92
eray92's Avatar
Re: motor questions
Love the sound of an rb20. Do this and run a nasty turbo and 3" straight pipe
eray92 is offline   Reply With Quote
Old 09-26-2013, 08:36 AM   #6
eray92
eray92's Avatar
Re: motor questions
http://youtu.be/iMYrnDcUkXs
Here's a 2jz c10
Old 09-26-2013, 09:25 AM   #7
79Betty
79Betty's Avatar
Re: motor questions
That is awesome. Love the jack door's
Old 09-26-2013, 10:01 AM   #8
kalbert
Re: motor questions
I know it's not as far out of the box as some of you are thinking, but it's pretty high on the neat scale. There's a couple of youtube vids showing guys that used 453T Detroits
Albeit not a pickup, you've all seen the 24V Cummins Monte right?
kalbert is offline   Reply With Quote
Old 09-26-2013, 11:27 AM   #9
tommartin
tommartin's Avatar
Re: motor questions
what are the specs on the motor? Hp, torque...
tommartin is offline   Reply With Quote
Old 09-26-2013, 12:49 PM   #10
MalibuSSwagon
Re: motor questions
There is a guy in Canada on here who has a Lexus 4.0l V8 mated to a T56 in his C10. There is another guy in New Zealand with a Toyota diesel in a C10.
MalibuSSwagon is offline   Reply With Quote
Old 09-26-2013, 02:00 PM   #11
eray92
eray92's Avatar
Re: motor questions
Engine
Type (see below) RB20DET Twin cam, in-line 6, Turbocharged
Displacement 1998 cc
Compression Ratio 8.5:1
Max. Power; kW/bhp 160/214 @ 6400 rpm
Max. Torque; Nm/ft-lbs 263/194 @ 3200 rpm
Bore x Stroke; mm 78 x 69.7
Redline 7600 rpm
Fuel Injection Nissan EGI (ECCS)
gearbox
Transmission 5 speed manual
Gear Ratios
1 3.321
2 1.902
3 1.308
4 1.000
5 0.759
Reverse 3.636
Old 09-26-2013, 04:01 PM   #12
jpnh
jpnh's Avatar
Re: motor questions
Check this guy out.-jeffhttp://youtu.be/oR7NiZmxVAo
jpnh is offline   Reply With Quote
