Old 09-28-2013, 06:38 PM   #1
JMac11
JMac11's Avatar
oil sending unit solution
This is an answer for some of us not so mechanically inclined..... for mechanical guage, remove factory sending unit, insert bushing and adapt line to 1/8 npt for mechanical guage.......not connected to company in anyway
http://www.racingplanetusa.com/drain...FY5r7Aod03UADA
JMac11 is offline   Reply With Quote
Old 09-28-2013, 10:39 PM   #2
Blackpony
Blackpony's Avatar
Re: oil sending unit solution
I just drilled and tapped the small adapter on the driver side of the oil pan. installed the factory sender and my factory gauge works..
Blackpony is offline   Reply With Quote
Old 09-29-2013, 02:51 AM   #3
truckdude239
truckdude239's Avatar
So that fits where the stock oil sensor for the ls screws in?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-29-2013, 02:16 PM   #4
JMac11
JMac11's Avatar
Yep.....
Old 09-29-2013, 03:32 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: oil sending unit solution
So if you take the senor that is in the block now out and make it where you can use a mechanical as in the truck now how does the computer work and where does it hook up?
I have the Speed Hut electric gauge in the truck now would I be able to to hook straight up to the electric sendor in it now u think?
U can see the electric senor on the fire wall above the runners on drivers side.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-29-2013, 09:09 PM   #6
truckdude239
well my harness place removed the oil pressure sensor from the harness i'm told the computer doesn;t need it
David fuller
2000 Tahoe 5.3l 378
Old 09-29-2013, 11:17 PM   #7
BigRed76
BigRed76's Avatar
The factory oil pressure sender on the 4.8/5.3/6.0's is only for the oil pressure gauge in the trucks they came in. The PCM does not need the oil pressure sender so that's why you can eliminate it and use your mechanical gauge
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 09-30-2013, 02:00 AM   #8
crazy longhorn
Fabricate till you "puke"
Auto meter sells an adaptor bushing, to go into the top of the block. It is listed for elect gauge apps....but if you add an 1/8" pipe male/1/8" tube compression fitting, you can run a mechanical oil pressure guage right off the top of the block. It was 14 bones for both parts....the auto meter "bushing: was 11 dollars, & the 1/8" tube , compression/ 1/8" male pipe Was a 3 dollar Napa part? My oil pressure guage will hook in about the same spot as it did with the Gen I smallblock. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-30-2013, 10:34 AM   #9
solidaxel
solidaxel's Avatar
I did the drill and tap the oil filter adapter for the stock 350 item AND plan on using the stock oil pressure sending unit as I want to monitor the OBDll with a remote Android
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-01-2013, 09:29 PM   #10
BigRed76
BigRed76's Avatar
Does your oil pressure sending unit have wires going to the PCM?
Zach
Old 10-01-2013, 09:37 AM   #11
Jon01
Jon01's Avatar
I snapped the plastic part of the stock sender off then drilled and tapped it for 1/8" NPT.
Works like a charm.
Jon01 is offline   Reply With Quote
Old 10-01-2013, 10:06 AM   #12
Billett
Billett's Avatar
I did the same thing, but with the autometer sending unit I have it hits the valley cover bolt right there. Will the autometer adapter get the sending unit high enough to clear that bolt?
Right now I have a temp sensor in there just to fill the hole... haha
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-01-2013, 10:20 AM   #13
JMac11
JMac11's Avatar
Actually tapped the fitting by the oil filter myself, used an oil plug to cap the hole on mine.....
Old 10-01-2013, 10:40 AM   #14
Billett
Billett's Avatar
I might have to tap the block off plate by the filter, just thought it would be much cleaner/easier to wire in the stock location than down there.
Will
2024 Toyota Sienna
