09-29-2013, 12:47 PM | #1 |
door panel and arm rest removal.
I nerd to pull the driver side armrest and door panel off my truck. I can't see what's bonding the arm rest on . Flat head , Phillips, or bolt . Its on a 1972 GMC. Can anyone help me out ?.
Posted via Mobile Device |
09-29-2013, 12:50 PM | #2 |
Re: door panel and arm rest removal.
Should be a large phillips.
09-29-2013, 12:55 PM | #3 |
I'll give it a try thanks
09-29-2013, 01:49 PM | #4 |
your gonna need a door window roller crank tool if you dont have one. It is kinda flat and has a u-shaped groove in the end to push the clip off the window roller. A tip the clip opening should line up with the end you put your hand on to roll the window.
09-30-2013, 12:08 PM | #5 |
You can also remove that clip with a 90 degree bent dental pick.
Look closely with a flashlight. You'll see the clip and how it fits. Do one side and keep the other door intact so you have a reference for putting it all back together. |
09-30-2013, 02:24 PM | #6 | |
Ask me how I know!
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
