09-30-2013, 08:31 AM | #1 |
Ring Gear change
How much of a difference would i see if i went with a 3:42 ring and pinion. I currently have the factory 3:73 rear end.
I want to keep my low end power but have a little better MPG and lower engine RPMS at highway speeds i do have a 2000RPM stall converter
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-30-2013, 08:39 AM | #2 |
Re: Ring Gear change
A 3:42 adds one tooth to the pinion. So roughly a 10% change.
If you're turning 3000rpm on the freeway, after the change 2700 rpm. If you were getting 10 mpg, expect 11 An overdrive transmission is about a 25% change.
10-01-2013, 11:44 PM | #3 |
I would go with the overdrive.More expensive, but pays bigger dividends in the long run!
10-02-2013, 02:42 AM | #4 |
not worth the troubel/ expense to swap from 3.73 to 3.42,IMO. Same could be accomplished with taller tires.
